Need parts for Lincoln Welder
发表于 2021-8-31 22:08:49 | 显示全部楼层 |阅读模式
I am thinking the wire feed motor on my Lincoln Weldpak 3200 went out.  I have failed to to locate another one on the internet.  Anyone have any ideas on where I can look to find another one?
Reply:Download the manual from the Lincoln site, locate the motor, get the part number, then contact your nearest Lincoln distributor for where to buy one.If you remove the motor itself, note the specs and shaft length/diameter you may be able to play matchup with another motor with better specs.
Reply:looking for a fan blade for sa 200 cant find one anywhere...help
Reply:For your SA200 fan try calling it probably won't be listed new on their site but they might have it used.http://www.billswelderrepair.com/Engine-Drives.htmlhttp://www.stumpfweldingsupplies.com/http://www.hybriweld.com/
GMT+8, 2026-1-2 18:16 , Processed in 0.178450 second(s), 18 queries .
