filler neck repair
发表于 2021-8-31 22:08:49 | 显示全部楼层 |阅读模式
can anyone give me ideas on how I might repair the threads for gas cap on the filler neck of weldanpower 225 with briggs engine? Or if replacement tanks are avaliable for model 8551.The one on mine are damaged enough the cap will go on but leaks gas which is not good when welding.
Reply:Pics?My name's not Jim....
Reply:Does it look like this one?http://cgi.ebay.com/FUEL-TANK-HOMELI...item53dfb92cbaMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:hope this works for pics this is my tank
Reply:Hey dere;I had the same problme on that oval tank with the 16 HP Briggs. Write me back and let me know if you are still looking for help on this. I thyink I can help you with the part. Originally Posted by jkh23046can anyone give me ideas on how I might repair the threads for gas cap on the filler neck of weldanpower 225 with briggs engine? Or if replacement tanks are avaliable for model 8551.The one on mine are damaged enough the cap will go on but leaks gas which is not good when welding.
Reply:Look under the fuel tanks section this guy has new necks and caps.http://www.enginads.com/pedersen/
GMT+8, 2026-1-2 18:18 , Processed in 0.103519 second(s), 18 queries .
