Questions on Weldanpower & Compatibility
发表于 2021-8-31 22:08:49 | 显示全部楼层 |阅读模式
Hey dere;Now I got a Weldanpower 6000 Watt, Code 8928,circa 1985,  and want to run a Tomahawk 375 Air Plasma cutter right off it. Now  I would like to hear if this would work out or not before I buy one , for sure. On the tech site from Lincoln they say input of the Tomahawk is 208/230/1/60, so what also, does that mean?  Appreciate any comments.
Reply:208-230v input voltage single phase. The Input Amperage would be essential too know. My WP is 6KW, 26amps MAX at 230v.Found the specs on Lincoln site, 21.6amps at full load capacity, should be good to go!!Last edited by MadMax31; 03-25-2011 at 08:19 PM.Reason: infoLincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Mad mad31;Just wanted to say thanks, that's what I needed to know. VERY refreshing to get straight answers. All hte best
GMT+8, 2026-1-2 18:17 , Processed in 0.093903 second(s), 18 queries .
