F-162 SA 200 Oil capacity?
发表于 2021-8-31 22:08:48 | 显示全部楼层 |阅读模式
I just picked up a SA 200 & want to change the oil first thing. What is the capacity & oil weight for warm climate? I am trying to find out the year of the machine anyone know where to look for the serial # There is a plate on the side of the engine with a code # & engine # but i do not believe this is the serial #American by birth Southern by the Grace of God
Reply:Hi 74,I set out to find that out as well just recently. It looks like it should be somewhere around 4-1/2 qtz. by the Lincoln engine manual.  http://billswelderrepair.com/files/L-Head_Overhaul.pdf  cheers kamotz
Reply:Hey check out the SA200 sticky, I think that I read in there that the capacity of my 163 is 5 quarts. I am running SAE30 Heavy Duty, and a NAPA 1050 filter.
Reply:ok great, Now i have to find the serial #American by birth Southern by the Grace of God
GMT+8, 2026-1-2 18:19 , Processed in 0.097670 second(s), 18 queries .
