anyone use optrel weld cap helmet?
发表于 2021-8-31 22:08:46 | 显示全部楼层 |阅读模式
Hello,I do allot confined spaced welding on ships-subs. I currently use a passive Leather hood I'm borrowing. I own a miller elite and viking helmets but they banged up bent  at times when I need to stick my head into a tight crevices. Has anyone used the weld cap by optrel? How does it compare to a miller elite  hood in size? Is the facial and side areas flexible? My next option is a tillman leather hood with a miller 2x4 auto lens installed in a hood from tillman.
Reply:I have tried it but does not work for me. The size is not much different than using a regular hood in my opinion. Yes, the face area under the lens and the sides are flexible, is made of fire  retardant cloth. For work in tight places I made my own hood instead. Like a skiing mask to cover everything but used denim as material then used welding goggles. Works fine for me.
Reply:If you cold find something similar to this. Its much better for confined spaces. Is also available on ebay
Reply:Looks cool! Like an iron man mask lol. what's  it called?
Reply:Maybe that's what Ozzie wears when he welds
Reply:Originally Posted by All positionsLooks cool! Like an iron man mask lol. what's  it called?
Reply:Google "servore auto darkening goggles" 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Ok i got try out the arc 513 sevore goggles They fog up pretty quickly. Will have more info later. I'm  still interested in the optrel weld cap. But for now. My leather hood amd arc one lens will do
Reply:The photos silvertina posted look fairly similar to the Miller "Weld-Mask".I tried on the Optrel weld cap and the only place I could get it to feel OK on my nose put the back of the mask really, really close to touching at my cheek bones and eyebrows.  I am not claustrophobic but felt like something was in my space...you know, always wanting to brush it away?I am also not sure how the optics would be after longer periods of use, I have found I need to be pretty particular about things like sunglasses (for me it is usually the slight curvature, close to the eyes).
Reply:I sold mine and went back to 3m 9100xxx. Just didn't like the fit.V
Reply:I tried it on at fabtech before it was released, i thought it was horribleTorchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
GMT+8, 2026-1-2 18:18 , Processed in 0.068928 second(s), 18 queries .
