Electrode Storage
发表于 2021-8-31 22:08:45 | 显示全部楼层 |阅读模式
What do you guys have set up to organize your stick electrodes?Last edited by 17jamato; 01-22-2015 at 09:50 PM.Miller Dialarc 250 AC/DCWeldcraft A-150VSmith O/P
Reply:A whole bunch of the plastic containers with O rings in them...GravelThe difference between theory and practice is that in theory there is no difference.
Reply:I use the 10 pound tins , just reuse them and fill from a 50 pound box. I also have a couple rod guard holders for mobile stuff.
Reply:pvc pipe of various sizes, mostly 3" though.   two caps- one glued.   paint color code them.   do the same thing for tig wire
Reply:I keep all my tig rod in pvp tubes. Green caps= carbon - Silver caps= stainless - White caps= otherI keep all my stick rods in hermatically sealed cans, open as needed (1 at a time) and placed in Rod Guard tubes for safe keeping.  Attached ImagesLast edited by Murphy's law; 01-23-2015 at 06:23 AM.Reason: picture
Reply:these harbor freight ones work and are inexpensive, $ 4.99 sale and use a 20% off coupon and buy for $4.00  http://www.harborfreight.com/welding...per-46477.htmlWelding Rod KeeperChicago Electric Welding - Item#46477
Reply:Shelves for unopened cans, rod oven for loose rods, out of the oven into plastic o ring tubes when going portable.REAL TRUCKS DON'T HAVE SPARK PLUGS
Reply:I use a couple .50 cal ammo cans. They hold three 50# cans and several 5# and 10# packs. They are air tight and have worked well.
Reply:Originally Posted by GravelA whole bunch of the plastic containers with O rings in them...
Reply:7018 in the rod oven or sealed air tight containers with desiccant in them. All other stick rods sitting in boxes on the shelf, some opened and some not opened.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:i have a shelf under my bench for the unopened cans and one open container of 1/8 and 3/32" 6010 rods.  7018 and stainless are in the oven.i.u.o.e. # 15queens, ny and sunny fla
Reply:I usually don't do much stick welding at the house, so I usually buy them as I need them. But lately I've been doing more and have considered finding a broken mini fridge to throw a 100w light bulb in. Rod ovens are too expensive, and hopefully this would keep my rods hot enough. It's not like I'm doing X-ray work at my house haha."If you ain't making mistakes, it means you aren't learning anything."
Reply:FarmerJoe, what if you need to repair your stock trailer?Put the rods in the kitchen stove?LOL!I keep mine in the furnace room as it is relatively dry.No need to worry about X-Ray as my wife took away my X-Ray Specs when she caught me looking at the neighbor girls!HA!HA!
Reply:This is how i keep mineSent from my SPH-L710 using Tapatalk Attached ImagesMiller Dialarc 250 AC/DCWeldcraft A-150VSmith O/P
Reply:I make tubes from pvc for 2 bucks each.
Reply:Originally Posted by farmer37I make tubes from pvc for 2 bucks each.
GMT+8, 2026-1-2 18:17 , Processed in 0.098926 second(s), 18 queries .
