Another soda can.....
发表于 2021-8-31 22:08:44 | 显示全部楼层 |阅读模式
another can, I haven't done one for awhile and wanted to see if I was still sharp.....  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:where is it  1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Last edited by B_C; 02-10-2015 at 08:59 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Nice job BC. I've tried a couple times and have trouble getting the 1/16 filler to melt. What size tungsten you use?
Reply:Excellent, No doubt about it B_C you are definitely sharp.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Beer Can's Welding."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Have you tried cutting a can in half and welding it back together yet?
Reply:I had to do a few of those for one of my welding tests, I used a super small .040 tungsten and no more than 50 amps, but I tried the 4943 filler, it almost felt like cheating cause it flows so nice.BC, your cans look better than mine. Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:That's awesomePsalm 121:1-21 I lift up my eyes to the hills—    where does my help come from?2 My help comes from the Lord,    the Maker of heaven and earth.
Reply:You're such a stud Bill Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Niiiiiiiice! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by walkerHave you tried cutting a can in half and welding it back together yet?
Reply:Originally Posted by MinnesotaDaveIs that actually possible?Nice can welding BC Makes me want to try it again and see if I can duplicate that nice of a weld with my old beastie
Reply:I did a few, I actually liked the transformer machine better than my Dynasty.
Reply:Originally Posted by OscarUnder the right conditions, I don't see why it wouldn't be.  You'd have to get down to the scale of the thickness of the can-wall to see how it would be no different than welding thick-wall pipe IF you can get your tungsten sharp enough and with an atomic-distance arc length.  Must have steady hands, I imagine.
Reply:Originally Posted by motolife313You can probably just turn on a dynasty and it will weld its self together.
Reply:Originally Posted by OscarHere is the cheater lens that you need to do this successfully:
Reply:Ok, some TIG machines go down to 1.5 or 2 amps. Lets see some aluminum foil welded together.
Reply:Originally Posted by Welder DaveOk, some TIG machines go down to 1.5 or 2 amps. Lets see some aluminum foil welded together.
Reply:Originally Posted by motolife313Nice job BC. I've tried a couple times and have trouble getting the 1/16 filler to melt. What size tungsten you use?
GMT+8, 2026-1-2 18:20 , Processed in 0.071405 second(s), 18 queries .
