Air compressor off engine drive
发表于 2021-8-31 22:08:43 | 显示全部楼层 |阅读模式
I have a Hobart champion 16 engine drive welder that I use a airarc k2000 on hers and there. I have always done it at my shop with my smaller air compressor and it works fine. But I'm setting up a welding trailer and is it OK to run that 110 compressor off my welder while using it for arc gouging or would I be better to run the compressor off my small generator?
Reply:Check the machine's manual. Many engine drives you don't get full aux power if you are "welding". So if you have the airarc up at say 75% of max, you'd only have something like 25% of the aux gen capacity left to run an air compressor. I know the Miller Bobcats are this way, and I believe the Hobart Champions are similar to the Bobcats other than they are CC only units.I know one of the big selling points of machines like the Trailblazer is that they have separate welder and generator systems, so you have both max weld and aux power available at any time..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:From the Champion 16 manual page 3-6:Champion 16 Maximum Auxiliary - Weld Combination.docMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:The biggest issue will be compressor start-up amperage draw while air-arcing.  If already running or running continuously not so much so but probably better to run the compressor off the genny.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Ok thanks, that's what I was thinking I would have to do.  Would like a gas powered compressor but that's just not in the cards rite now.
Reply:I'd have to say a machine that small unless you are running some really small carbons I don't think it'll probably work so well.-DoogieMiller 350PMiller Trailblazer 325 EFI w/ Excel PowerLincoln LN25 suitcase welderXMT 304/22a feederMiller Syncrowave 350LXMiller EconotigHobart Handler 140(2) Uni-Hydro 42-14Hypertherm 65 plasmaWEBB Gap bed lathe
Reply:The rods I use are 5/32 they work good with my machine and compressor, but I don't use the setup alot.  60% of the work I do is fab and the other 40% is repair.
Reply:You can get a air compressor head that is ran of the engine itself. It has a electric clutch on to control when it need to build pressure. Just add a tank to support it.Klutch 220si mig , stick, and dc tigHobart 140 AHP ALPHA 200X 2016Lotos LTP5000DSmith O/P
Reply:Originally Posted by tinker001You can get a air compressor head that is ran of the engine itself. It has a electric clutch on to control when it need to build pressure. Just add a tank to support it.
GMT+8, 2026-1-2 18:19 , Processed in 0.105513 second(s), 18 queries .
