new helmet and installing cheater lens
发表于 2021-8-31 22:08:43 | 显示全部楼层 |阅读模式
Hello all, just purchased a passive lens helmet, because I was getting tired of having to switch between the welding helmet and the grinding face shield. must say, other than it being a little tricky striking the initial arc. it's really not that bad. in fact, once I get the arc started, I can actually see better than with the auto darkening helmet. I realized that the auto darkening has a green tinted lens which might have impaired my ability to see things clearly.  I've been wearing glasses under my helmet which has also become a pia. so I just ordered a cheater lens for the new helmet. I'm very happy that I made this purchase.
Reply:What helmet and lens did you end up with?
Reply:I purchased the hobart helmet on amazon for $13 with free shipping for a trial of amazon prime. it looks like the old style pipe worker helmet. it has a shade #10 lens and a clear lens.
Reply:for the last 25 years or so i wear both a cheater and my prescription eyeglasses under my passive shield. i use a flip front fibre metal and i put the cheater under a clear lens in the shield itself not the flip part. i believe this gives the cheater some added protection.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docwelderfor the last 25 years or so i wear both a cheater and my prescription eyeglasses under my passive shield. i use a flip front fibre metal and i put the cheater under a clear lens in the shield itself not the flip part. i believe this gives the cheater some added protection.
Reply:Originally Posted by HT2-4956doc,That's been my seeing solution for welding for a while also.   My prescription glasses are no line bifocals.   Concerning cheater lenses...have you tried the ones made out of glass instead of plastic?   I recently switched over to the glass ones and found they give me much better clarity of vision.
Reply:Originally Posted by docwelderht; i'm using the anchor brand plastic #2 cheater that the dept supplies. i never thought about the glass ones. thanks for the heads up i'm going to check it out.
Reply:Speaking of the glass cheaters, my LWS took forever to special order a #3 plastic cheater. While I was waiting I found a used glass #3.25 on ebay for a buck. They both arrived at the same time and the glass one is better. You can tell the shapes are a little better.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:again on the cheaters; long ago i saw a custom glass cheater that had individual lh and rh sides to compensate for differing eye strengths.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by shovelonSpeaking of the glass cheaters, my LWS took forever to special order a #3 plastic cheater. While I was waiting I found a used glass #3.25 on ebay for a buck. They both arrived at the same time and the glass one is better. You can tell the shapes are a little better.
Reply:Originally Posted by docwelderagain on the cheaters; long ago i saw a custom glass cheater that had individual lh and rh sides to compensate for differing eye strengths.
Reply:I just had my optician put a script in a set of uvex safety glasses set with welding distance  work greattrailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
Reply:Does anybody know if any of the glass cheater lenses have an impact rating?
Reply:Originally Posted by gundog77Does anybody know if any of the glass cheater lenses have an impact rating?
Reply:I had this same issue for a while and finally got fed up with all those "layers" of plastic between my eyes and the work.  So the next time I bought glasses, I told the optometrist I needed a prescription for some single/near vision, just for welding.  Then I took that prescription and bought some simple, but sturdily built, plastic framed glasses from one of these online stores for about $12.00.  Took the cheater lens out and tossed it.  Problem solved.-RuarkLincoln 3200HDHobart Stickmate LX235TWECO Fabricator 211i
GMT+8, 2026-1-2 18:17 , Processed in 0.101804 second(s), 18 queries .
