I know this is going to sound stupid but hey i will ask anyway.First let me tell you a little about me,just retired and going to start tinkering,had an Lincoln stick welder that i could run a bead but that was about it anyhow wanted a Mig and bought one. The question i have is is the torch energize at all times or just when you pull the trigger?Got it all about set up and ready to play just curious before i begin.Thank's
Reply:Just when you pull the trigger Welcome to the forum.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:To be sure, wet your hand, grab the work clamp and touch the end of the wire to your tongue. Just ing. What Ed said.Welcome to the forum. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thank'sI do appreciate and yes that's a good way to tell,been zapped enough in my career |
