stock pot repair
发表于 2021-8-31 22:08:38 | 显示全部楼层 |阅读模式
This aluminum pot came in from a restaurant.  Apparently the only replacement pots available in this size are stainless, which is too heavy for the customer, so I replaced the bottom with 3003.  It was .125" thick material but I used .188" for the repair.  I'm glad the diameter of the pot wasn't much smaller or I couldn't have fit my big head in there to see what I was doing.  Once I got it cleaned up, it welded up pretty good, no different than a manky boat hull repair.  I didn't quite blend the toes in as well as I hoped, but I think it will hold up just fine.
Reply:Nice looking repair.
Reply:Now that will work fine.
GMT+8, 2026-1-2 18:20 , Processed in 0.102805 second(s), 18 queries .
