Need some F162 Valve Spring Seats
发表于 2021-8-31 22:08:38 | 显示全部楼层 |阅读模式
I need 8 Valve Spring Seats for a F162 engine
Reply:http://estore.elginind.com/shoppingC...cat=Valve+Seathttp://catalog.mahle-aftermarket.com...?motorId=87307
Reply:You mean valve seat or shim under the valve spring? Don't forget to check your installed height and pressure
Reply:I need the metal seat at bottom of valve spring.It is for a drilled stem valve.
Reply:[attach=config]1024501[/attach]
Reply:It appears as though you're looking for a "valve spring retainer". Try that in your search and see if anything turns up.
Reply:They don't make these anymore.I will have to buy used ones from somebody.
GMT+8, 2026-1-2 18:15 , Processed in 0.185185 second(s), 18 queries .
