Esab Mig...uneven terrain mod
发表于 2021-8-31 22:08:37 | 显示全部楼层 |阅读模式
Build this cart for my Esab Migmaster 251 to ride around in.  Because of the size of bottle on it going over uneven terrain (like transition from concrete garage floor to crushed asphalt outside) is a sketchy proposition and requires more pushing, lifting and overall effort than I'd like.  So I built this cart out of 1.5" round steel tubing and 1" square with some 10" casters from eBay.  Now it has a much wider stance and taller tires to roll over obstacles, and I'm not as worried about tipping the damn thing over rolling outside the garage. Attached Images
Reply:That should work, nice job. Looks cold there! LolYeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:I like it! Working on uneven ground is a pain, gotta' have a low center of gravity, wide base, and big tires. Mr. HE
Reply:Good idea.*************************************Mike AccardiHenderson, [email protected] 250XLincoln Weldpack HDMiller Syncrowave 180 SD*************************************
GMT+8, 2026-1-2 18:36 , Processed in 0.073749 second(s), 18 queries .
