Recent shop projects...
发表于 2021-8-31 22:08:37 | 显示全部楼层 |阅读模式
Here lately I been having a lot of my buddies hounding me on building some new shop eqpt to make our hotrodding/racing/restoration projects go easier check me out....First we have my custom rearend station ready for actionUp next is a lightweight welding table...Overkill is underrated.....Last edited by chevyracer8262; 02-16-2015 at 12:52 PM.
Reply:Up next an autoframe and body dollyOverkill is underrated.....Last edited by chevyracer8262; 02-16-2015 at 12:53 PM.
Reply:And finally a coiled tubing straightener...Also a 12" wide hyd press plate break...Overkill is underrated.....
Reply:Holly crap! You have been quite busy! Good job!
Reply:Cool jigs and tools!  Where are you located? Are you guys doing restores or resto mods or all of it?12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:I'm down in Saucier MS and we do a little bit of all of it restoration, resto mods, Prostreet, pro touring and full blown race.....Overkill is underrated.....
Reply:Body dolly in action...And discovered my next tool build I really needed a spreader bar setup to attach to my floor jack...Overkill is underrated.....
Reply:Well after last weeks jacking issue with lifting that body off the ford I built an adjustable jack spreader bar and rearend removal adapter for my jack just need to cut two pcs of round tube and tire tread to make the body lift ends right now it's configured for rearend removalBest of all it costed me $2.50 in hardware to go along with the scrap material I had lying around the shop...Overkill is underrated.....
Reply:Where did you get the rollers for the tubing straightener?
GMT+8, 2026-1-2 18:16 , Processed in 0.100122 second(s), 18 queries .
