Welding/Fabrication Table 4ftx10ft For Sale
发表于 2021-8-31 22:08:33 | 显示全部楼层 |阅读模式
This is my 3 month old welding/fabrication table.  I made a full description post on the Craigslist ad.  I uploaded 800x600 larger copies of the same pictures shown on Craigslist to this post on the forum.http://longisland.craigslist.org/tls/2861790417.html. Attached Images
Reply:elbob,I hate links to other websites. So help me out here....How much?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Joker11, the price is $600.Rob
Reply:Bump, I thought this would have been a good deal.
Reply:Its a great deal. I'd buy it if you were closer
Reply:Thanks joeBump
Reply:im in freeport long island..hmm gotta find room in the garage...Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Do you have ANY sort of lifting points in the garage?  I could bring an overhead hoist and some chain to lift the front end of this beast up and put rollers under the front legs... drive my flat bed under it use the winch and hoist from there.
Reply:Cripes... just out of curiosity... what does a 4x10 slab of steel run these days at the supply house?
Reply:I designed a set of lift braces and small footprint dollies that allow the table to be lifted off the ground with a pallet jack.  Using those, the table can be raised onto the two dollies and wheeled out into the driveway.The 4x10 slab of steel quotes ranged from $550 to $900 depending on who I called.
Reply:Table is SOLD
GMT+8, 2026-1-2 20:21 , Processed in 0.157094 second(s), 18 queries .
