I have small Craftsman horizontal bandsaw that needs a new blade. Any good online sources for good quality blades? Thanks
Reply:I get all my bandsaw blades from Enco. Good pricing and service.www.use-enco.com/
Reply:I use MSCDonnelly Small Engine & WeldingFoley AlabamaLincoln 225 TigLinoln 215 migHypertherm Powermax 65Ellis 1600 sawEllis 6000 belt grinderJD2 Model 4 tubing benderAtlas 12"X54" metal latheLots of large hammers
Reply:1/2", .025" wide bandsaw blade material purchased from your local sharpening shop, cut and welded to desired length works OK on the old craftsman bandsaws (although they are originally designed for slightly thinner blade, which is much harder to find and not really necessary.) I believe going from memory, the blade length is 4 feet. You can select various teeth per inch based on what you will most often be cutting.
Reply:http://olsonsaw.net/64-5bm.htmltackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Try saw blade.com
Reply:Is this a metal cutting horizontal band saw like a 4''x6'' ? What's your location ?Do you have a Farm and Fleet where you live ? Their blades are USA made and at a reasonable price.
Reply:Thanks for the tips. Yes it is a small metal cutting saw. Don't believe I have seen a Farm and Fleet here in my area of Missouri. Should be able to find something from one of the places mentioned . Thanks
Reply:I purchase my blades for my metal cutting band saw on www.sawblade.com . You may want to check the site. |
