What is the weight of Lincoln SA-200, around 1986-ish?
发表于 2021-8-31 22:08:24 | 显示全部楼层 |阅读模式
I will pick this one up soon:       http://igor.chudov.com/tmp/SA-200.jpgI have NO idea about its condition. It is an auction deal, sight unseen. My hope is that it runs.My question is, how much does it weigh?You think it has a F-162 Continental engine?Serial number is A-1069925. Attached Images
Reply:Can someone remove those spams???
Reply:right under 1300lbs, I do believe.I hauled mine home in the bed of a 1/2 ton 2wd truck.1981 Lincoln SA 200Miller Trailblazer 302gMiller 211 Mig Welder w/ AutosetI'm learning to stick metal together
Reply:Thanks a lot! I have a 3/4 ton.
Reply:Picture at pickup is herehttps://picasaweb.google.com/lh/phot...eat=directlink
Reply:Where do you find the serial # on these SA 200'sAmerican by birth Southern by the Grace of God
Reply:face plate and on the engine
Reply:My faceplate must have been replaced & it is not stamped in it. I found the 4 digit code on the generator but would like to find a serial # anyone know where to look?American by birth Southern by the Grace of God
Reply:Look under the band that is around the barrel1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:The serial number you are looking for is on the faceplate and is not found in any other place.Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Is there any way to find the serial # I have a four digit number stamped in the Generator about the 11 o clock position.American by birth Southern by the Grace of God
Reply:Short of finding the original faceplate you are out of luck.I know this doesn't help but it is the truth.Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Will that four digit code give me the approx. year of the machine? ThanksAmerican by birth Southern by the Grace of God
GMT+8, 2026-1-2 20:20 , Processed in 0.133447 second(s), 18 queries .
