Invertec V300 very low output
发表于 2021-8-31 22:08:24 | 显示全部楼层 |阅读模式
I have an Invertec V300 that is not welding. The output is very low with the machine set on max there are just light sparks. The open circuit voltage across the output terminals is like 70.6 volts and the display shows 0 amps. This is the same for all of the settings mig, stick, and flux core. I have the welder set for 230 volts and the input power is good. I know I need to go through the machine, but If anyone has an idea of a good place to start I would appreciate that. Thanks.
Reply:sent you a PM
GMT+8, 2026-1-2 20:22 , Processed in 0.108501 second(s), 18 queries .
