messed up sa200
发表于 2021-8-31 22:08:20 | 显示全部楼层 |阅读模式
well i was looking at welders on cl and found this sa200 http://sd.craigslist.org/bfs/4867438961.html . i was wondering what you guys think its worth or if its even worth buying .
Reply:tough call man, sheetmetal for those is pretty pricey.you may be able to straiten the hood, run without the fan shroud, straiten or just remake the radiator support/cover piece, buy a new radiator and have a runner but. . . . .that thing looks pretty scary.if i really really wanted it, i would offer 200$bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:If you got the skill to fix it, offer $200 and haul it home. You'll get more for it parting it out so you won't get hurt.Hard to say how bad it's wanged. It may run and weld fine with some TLC.DLX and I are reading each other's minds  Typing at the same time Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:what do bottom of the barrel  running welding sa200s go for ? i looked at radiators and i found a new one for 300 . the things im concerned with is where the controls are and the missing nose cap .
Reply:Seen them sell for under $100 before. Average price depends on a lot of factors. There's no set price. Depends on location, age, style, condition. Seen a fair share of aluminum wound machines sell for $500 in running condition tho. Bought shorthoods for that too.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:honestly ive seen running sa200s go for 500$ in my area if you had one already and need some parts it could be worth other wise id stay away from it.High Octane Welding
Reply:Originally Posted by K98dkmauserwhat do bottom of the barrel  running welding sa200s go for ? i looked at radiators and i found a new one for 300 . the things im concerned with is where the controls are and the missing nose cap .
Reply:this is my machine run through. started knowing nothing and finished knowing a bit more.http://weldingweb.com/vbb/showthread.php...revival+threadthink of it as a "worst case". let me know if you have any questions i like to try and helpbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:That's an octagon barrel machine! When it rolled off the assembly line it was just another welding machine, nothing special at all. The Lincoln SA-200 octagon barrel machines weld just like a Miller Big 40.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:If it were close to me I'd jump on it. I can fix most all of the body damage. If you must buy each and everything you should pass.
Reply:well i called on it he said the least he would go is 325 so told him that was about 125 to much . i figure i dont need a generator welder but if he still has it in a month it would make a fun project to work on .
GMT+8, 2026-1-2 22:15 , Processed in 0.095320 second(s), 18 queries .
