My first tig.
发表于 2021-8-31 22:08:19 | 显示全部楼层 |阅读模式
So I pulled the trigger on an green tig. (I know I know) however while I was waiting for it to come in I went to the lws to get some tungsten and filler rod and I met a guy talking about a miller econotig that he got that he didn't want. So I said I would buy it from him. I handed him a business card and he said oh you tattoo I would trade ya straight up. I said hell yea. I picked up the blue machine last night and gotta  plug wired in the garage tonight. Fired it up and start running my first ever tig beads. This is my 6th attempt. The torch I have has a slider gas valve and the cable on he torch is old and stiff and the torch slid in my hand and shut the gas off last minute. Plus I didn't add enough filler rod and it cratered a little bit. Overall I am pretty happy with this rig not knowing much about tig yet. I have done a lot of reading here and a lot of YouTube videos. I think being a tattoo artist helps with my hand control and being a drummer helps with my multi limb coordination.Now my green machine will be here Wednesday and I think I am gonna send it back. Using Tapatalk
Reply:Not bad at all..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Two days until my green machine floats in on the barge. Not a bad bead at all man.Powcon 300st (my favorite)Miller Goldstar 600ssLincoln Idealarc 400/400Miller 12vs2 LN25'sMiller Deltaweld 302Miller Bobcat 250 G EFIMiller Bobcat 225d Plus (Dropped a valve, up soon)Everlast 255ext (ordering soon!)
Reply:Looks good. Your ready for a t joint! Post the pics
Reply:You might be able to resell that green machine.I think you have an advantage, having a brand new unused machine on this side of the ocean.I see it all the time on ebay, people buy in bulk from china, then resell it for a few $ more. Seems there are some people out there who will spend a few more $ so they don't have to wait an additional week or 2.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:You've got to start somewhere and by the looks of it that's a good place to start...Lincoln Weldanpower A/C 225 D/C 210 /6kw auxiliary (code 9113 & 9108)Lincoln Weld Pak 100 MigMiller Maxstar 150 TigLincoln Scratch Tig 200 ampMiller 8-VS Suitcase Flux CoreHypertherm Powermax 30Victor Torches / Regulators
Reply:I'm not trying to be negative, but while you wait for the green machine to arrive, you might want to compare the models.  The duty cycle may be significant, for instance.   The minimum amps may also make a difference if you want to work on some really thin stuff.A new tehcnology machine may be able to do tricks that a 10 year old model can not.Dan----------------------------Measure twice.  Weld once.  Grind to size.MIG:  Lincoln SP100 TIG/STICK:  AHP Alphatig 200X
Reply:Econotig only goes down to 30 amps on AC and 20 on DC pretty sure
Reply:Most of the stuff I do right now is motorcycle exhaust 16ga wall and body work stuff 16ga as well. It worked well last night on some exhaust tubing. I don't see myself going smaller than 18 gauge or so. I done a lot of research before pulling the trigger on the green one. The econotig fell into my lap so to speak and with the pedal I can get pretty low amp arcs. I really can't see myself needing to go any lower than 20 amp. The only thing I like about the green one is it is dual voltage and has pulse. Which I was messing with last night with the foot pedal. I don't know what to do now. I think I will keep the blue and sell the green one.Using Tapatalk
Reply:One of the guys i do work for has a econotig, i love it when i use it in his shop sometimes. Great little unit but shy on the amps.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
GMT+8, 2026-1-2 20:22 , Processed in 0.113125 second(s), 18 queries .
