Welding aluminum foil
发表于 2021-8-31 22:08:19 | 显示全部楼层 |阅读模式
Here ya go guys it can be doneI hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Making tents for baked potatoes? Looks good - I'm sure my Airco will hide if I try that....but I will anyway....no, I won't be posting the results Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Where's the bend tester?  And the tensile strength test?Probably doesn't even count without those Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I'm waiting for the HAZ comments I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeI'm waiting for the HAZ comments
Reply:Mike, just think of it..... Welded tinfoil hats...   PERFECT.     To ride, shoot straight, and speak the truth. This was the ancient law of youth. Old times are past, old days are done, but the law runs true oh little son.Winpower 180 DCSA-200 redfaceXMT-304
Reply:Mike did you do this AC or dc? And before everyone else comments, yes it can be done in dc.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleMike did you do this AC or dc? And before everyone else comments, yes it can be done in dc.
Reply:That is badass good job! I'd assume a dynasty?Millermatic 211Miller Syncrowave 350lx with cooler and tigrunner Thermal Dynamics cutmaster 811955 National Cylinder Gas O/A setup with original patina
Reply:How many hits with a 5 pound sledge will it take ?
Reply:Originally Posted by MinnesotaDaveYep, too wide - damaged the integrity of the foil on a molecular level....or atomic, depends on who you ask
Reply:I used to weld 2 gum wrappers together. You could hold a lighter between them for a few seconds and then mash them together and they would weld. Couldn't pull them apart.
Reply:Originally Posted by shovelonYep. Better send out for saturation annealing.
Reply:Geez Mike!I would have to put a 1/8 shim in there to get it to stick.  Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Send it to moto to get it bend tested, he'll do it for cheap!Nothing Ever Got Done By Quitting, Never Give Up.
Reply:A little trick I used was to take two pieces of foil, sandwich the foil together between two pieces of scrap steel in vertical position. With about 1/4 to 1/2 inch sticking out. Start an arc on one of the steel plates then run the arc quickly over the foil sticking out of the plates. Normally it worked, kinda cheating but had a lot of fun with it in school.
Reply:Originally Posted by Doug247Send it to moto to get it bend tested, he'll do it for cheap!
Reply:I think I would have to beef up my bender to get that piece to bend. It would take a serious grinder or saw to cut it in coupons.
Reply:maybe plasma cut it?Nothing Ever Got Done By Quitting, Never Give Up.
Reply:im still bitter about the 5$ i lost to a guy that did this lol. but, the bet was with his maxstar 150 and strait argon.bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Originally Posted by I sniff NitroA little trick I used was to take two pieces of foil, sandwich the foil together between two pieces of scrap steel in vertical position. With about 1/4 to 1/2 inch sticking out. Start an arc on one of the steel plates then run the arc quickly over the foil sticking out of the plates. Normally it worked, kinda cheating but had a lot of fun with it in school.
Reply:nice mike i have won a few bets on this oneMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Thank you guys!!!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by GambleMike did you do this AC or dc? And before everyone else comments, yes it can be done in dc.Originally Posted by weldermikeHere ya go guys it can be doneAttachment 1002371
Reply:Really......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Show us your aluminum can.......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:BUSTED MIKEY.....Hahahahaha  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Got awfully quite around here, lol.
Reply:IDK i think i saw a pic of a can Mike welded before and it had a pretty sick weave on it.Millermatic 211Miller Syncrowave 350lx with cooler and tigrunner Thermal Dynamics cutmaster 811955 National Cylinder Gas O/A setup with original patina
Reply:Originally Posted by zankOnly with lab grade helium
Reply:Ill never kiss and tell lol. I had one guy ask if i used filler, i told him yes...3/32.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeIll never kiss and tell lol. I had one guy ask if i used filler, i told him yes...3/32.
Reply:You can weld that with your eyes closed no problem.W
GMT+8, 2026-1-2 22:03 , Processed in 0.140957 second(s), 18 queries .
