Has anyone watched this? Big F**king HammerJumper cables & 2 marine batteriesJaws of life
Reply:Ok. That was random. Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:this guys going places..Mullets&Pullets
Reply:I thought the machine had to be specifically designed to do that. CC/CV machine?
Reply:Were those his real teeth?Sent from my SCH-I605 using TapatalkRyanMiller Multimatic 200 tig/spool gun/wireless remoteMillermatic 350P, Bernard/XR Python gunsMiller Dynasty 350, Coolmate 3.5 & wireless remoteCK WF1 TIG wire feederMiller Spectrum 375 XtremeOptrel e684Miller Digital EliteMiller Weld-Mask
Reply:If the very large mig welding capacitor were disconnected it may work.Only problems I see is the tig arc welding voltage is very low (11v to 15v) even compared to short circuit mig transfer (usually above 18v) so as long as the mig welding machine isn't smart enough to fault out for low voltage then it may work. The OCVs may make starting an arc very difficult. Typical mig OCV is usually over 30v where OCV for a tig can be any where from about 48v to up to 88v sometimes even higher on stick to tig converts like mine.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:Originally Posted by 1AgKidthis guys going places..
Reply:Why??Ernie F.
Reply:All I know is that it works.Big F**king HammerJumper cables & 2 marine batteriesJaws of life
Reply:I bet he hid the dc stick machine somewhere under one of those trucks and let the cable obstacle on the floor help hide it Blue stock- shopmaster, a/bp330, maxstar 150stl, maxstar 210, hf251, Tbolt ac/dc, mm 135Red stock-ranger 8, weldanpower 150, idealarc 250 ac/dcEsab plasma, Victor OA set, Air products ac/dc 400 ampIt's me flipped in snow..doughnut fail
Reply:Originally Posted by Michael rayI bet he hid the dc stick machine somewhere under one of those trucks and let the cable obstacle on the floor help hide it
Reply:yay...award deserved!!!
Reply:use your mig wire for filler since your not using your mig for mig.
Reply:I'm making a cheap China wire feed welder into a wire dispenser for tig. strange how some things just work
Reply:Someone's on the sauce....Big F**king HammerJumper cables & 2 marine batteriesJaws of life
Reply:it's your post...looks like the poster is hitting some sauce too...I wasnt being a dick...sometimes bad ideas turn out to be brilliant. I don't see it here though. I would worry about overloading the duty cycle or worse on a dedicated mig, who knows how long the tungsten will last and what kind of penetration is possible?? please run it for a while and post your results. I'd like to hear if the machine holds up and how the weld quality is.Last edited by Michael ray; 04-26-2016 at 09:34 PM.Reason: sauce I guessBlue stock- shopmaster, a/bp330, maxstar 150stl, maxstar 210, hf251, Tbolt ac/dc, mm 135Red stock-ranger 8, weldanpower 150, idealarc 250 ac/dcEsab plasma, Victor OA set, Air products ac/dc 400 ampIt's me flipped in snow..doughnut fail
Reply:ps...been sober since 1982. might drink 3 beers a year...never intoxicatedBlue stock- shopmaster, a/bp330, maxstar 150stl, maxstar 210, hf251, Tbolt ac/dc, mm 135Red stock-ranger 8, weldanpower 150, idealarc 250 ac/dcEsab plasma, Victor OA set, Air products ac/dc 400 ampIt's me flipped in snow..doughnut fail
Reply:I don't see any reason why it wouldn't work.The OCV would just be a little less than ideal. As long as the arc can start it will stay going in that argon stream.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder |
