Hinge Replacement
发表于 2021-8-31 22:08:12 | 显示全部楼层 |阅读模式
Few pics of 10whl dump tailgate top hinges i installed.Beauroc brand body dealer provided replacement parts.Pic of my weld as a few here have asked to see my welds.Did this to both sides.7018 1/8 Excalibur. Attached ImagesLast edited by admswelding; 03-08-2015 at 07:14 PM.
Reply:Looks good, how many passes did you make?Millermatic 211Miller Syncrowave 350lx with cooler and tigrunner Thermal Dynamics cutmaster 811955 National Cylinder Gas O/A setup with original patina
Reply:Nice stuff Adam. Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Originally Posted by That Guy ThereLooks good, how many passes did you make?
Reply:Nice looking hinge. Good looking install.
Reply:you do nice work.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docwelderyou do nice work.
Reply:Nice cuts.I am not even going to go into that cotter pin though..............................
Reply:Originally Posted by mikecwikNice cuts.I am not even going to go into that cotter pin though..............................
Reply:I am just messing with you.Giving a hard time and providing much needed sarcasm are what I am about!
Reply:I think he was hinting that you might want to replace it with a good quality double-rolled spring pin.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:lol.... or maybe he was just messing with you...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:I"m not sure what the wear is like in that situation (it looks quite well braced, so probably not that bad...), but I have had places in ag equipment where I've started replacing them with roll pins because of the wear. I like to use the double rolled pins if I need them because it's easier to drive them out with a small punch if the extra roll keeps the punch from going through the center. That is some impressive looking work though.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:There is not much side stress in this application guys.The cotter pin simply hold the 1-1/4"dia. pin from falling out.
Reply:Nice work Billy. Did you have to brace the sides? Sometimes, when you pull a gate, the sides usually flex out a bit, making installation difficult. I always used a com-a-long to tweak it back."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Stick-manNice work Billy. Did you have to brace the sides? Sometimes, when you pull a gate, the sides usually flex out a bit, making installation difficult. I always used a com-a-long to tweak it back.
Reply:You always make it look easy Billy Expert Garage Hack....https://www.facebook.com/steven.webber.948
GMT+8, 2026-1-2 20:22 , Processed in 0.120671 second(s), 18 queries .
