Hook lift repair
发表于 2021-8-31 22:08:12 | 显示全部楼层 |阅读模式
Customer dropped this truck off. Hydraulic cylinder snapped pin off lift arm.Had to burn out entire boss to get damaged pin out.Manufacture welded pin in backside of boss against lift arm as seen in pic.Customer had machine shop make new boss.Purchased pin from dealer.Truck does dumpsters if you didn't know. Attached Images
GMT+8, 2026-1-2 22:15 , Processed in 0.070874 second(s), 18 queries .
