Help Identify this welder
发表于 2021-8-31 22:08:00 | 显示全部楼层 |阅读模式
I bought this with the intention of restoring it, I was told it was a SA200, but after serching I'm not sure.It has a continintal F-163, the specs on the faceplate read 40 Volts, 300 Amperes, 100% duty cycle.Any help would be appreciated Attached ImagesLast edited by CINCH; 04-24-2011 at 03:29 PM.Reason: added picture
Reply:Wow, that is not an sa-200. I would say miller big 40.You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:It's a Miller Big 40, thanks Attached ImagesLast edited by CINCH; 04-24-2011 at 04:23 PM.
Reply:Looks like you have a under cover miller welder. Looks like it is blue under the grey paint.I have heard of people painting their welders so they can get their Miller welder onto a Lincoln only job site.
Reply:I have no doubt that happened(s) and just goes to show how much those that "call the shots" really know.  If it's gray and says Lincoln it's gotta be a Lincoln, right? MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-2 20:23 , Processed in 0.085878 second(s), 18 queries .
