in need of a muffler for my '57 sa200
发表于 2021-8-31 22:07:59 | 显示全部楼层 |阅读模式
currently my machine has no muffler....i have gone the route of attempting to have napa etc. look up mufflers that fit UNDER the hood on my '57 sa200 to no avail....any help would be appreciated as far as part # etc.
Reply:Try looking at tractor supply, the one here had a whole shelf with assorted shapes and sizes.
Reply:Your 57 is a F-162 runs at 1400 RPMs correct? My 54 is straight piped, and it is quieter than a F-163 that runs at 1550 RPMs with a muffler. Just make sure you use a good fitting rain cap to limit the amount of cold air sucked back into a hot engine. A lot of people run straight pipes just because they like the sound.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPYour 57 is a F-162 runs at 1400 RPMs correct? My 54 is straight piped, and it is quieter than a F-163 that runs at 1550 RPMs with a muffler. Just make sure you use a good fitting rain cap to limit the amount of cold air sucked back into a hot engine. A lot of people run straight pipes just because they like the sound.
Reply:It may not be an issue at all. I've always heard that cold air sucked back into an engine is not a good idea. But if you look inside most of these mufflers, there isn't much restriction.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by kamotzTry looking at tractor supply, the one here had a whole shelf with assorted shapes and sizes.
Reply:Many suppliers have some that have photos and measurements.:http://www.summitracing.com/search/D.../?autoview=SKUhttp://mower-blades.agrisupply.com/s...=muffler&asug=
GMT+8, 2026-1-2 20:22 , Processed in 0.109580 second(s), 18 queries .
