Auto structural strength.
发表于 2021-8-31 22:07:56 | 显示全部楼层 |阅读模式
Not sure if I'm on the correct forum, but here goes!  I recall seeing somewhere that I should beware of using ESAB All-State Easy-grind (Mig wire in my case) on auto chassis/frame/suspension repairs.  Any thoughts?  Thanks.
Reply:Why would you want to?Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:I have only seen it recommended for sheet metal.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Because it treats me well!
Reply:The wire is a standard er70s-6. Should be fine for that as long as your using a large enough wire that you'll get the required penetration.
Reply:Thanks, and speaking of wire, should I move up to .035" for welding 14ga. or stick to .030"?  Bearing in mind that I run a Millermatic 130 on 110V.
Reply:Stay with .030Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Thanks to all!
GMT+8, 2026-1-2 23:49 , Processed in 0.099413 second(s), 18 queries .
