max width of 3g GMAW
发表于 2021-8-31 22:07:55 | 显示全部楼层 |阅读模式
so did my mig 3g cert plates today. I believe its a 37.5° bevel 3/8 thick plate. So it was kind of a wide my question is whats the maximum tolerance allowed for this application?  Thank you in advanceJust good enough aint good enoughIf your gonna be a bad welder you better be a darn good grinder
Reply:I don't know if they have a maximum allowable width on a groove weld test but according to ASME codes there is no limit on how wide a weave can be. Somebody with the test specs. hopefully will be able to answer.
Reply:1 1/4" is what is for 3G smaw.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Ok mine is definitely within a 1 1/4 in. Its about an inch maybe 1 1/8Just good enough aint good enoughIf your gonna be a bad welder you better be a darn good grinder
GMT+8, 2026-1-2 20:22 , Processed in 0.382053 second(s), 18 queries .
