What size stinger connector or brand will ?Sent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:you can probably order right from sears replacement connectors....goto sears.com and put in the model and serial number for parts an manuals..
Reply:Open it up and convert those sockets to Dinse. You can get knock-off Dinse panel connectors for less than 10 bucks on Amazon, then a boat-load of leads will fit.Eventual master of the obvious, practitioner of "stream of consciousness fabrication". P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
Reply:I believe those use UP-10 connectors.Just get some UP-10 plugs and you can build your own stinger.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:In a pinch, you can get by with these. I made these to fit my miller cables so I could take them to my brother in laws to repair farm equipment. He has an old 250 amp Century welder for his farm. They are made from cable connectors, I ground the ends down to fit his Century welder with a 1 inch belt sander but you could do it with a good file. If you have cables already this might work for you. Be sure to tape them up really good with electrical tape before using, use red tape for the stinger.
Reply:I have a few century miller go between connectors and they didn't fit the miller receptacles I use very well. So I am using them as spot welding electrodes.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder |
