7018 at 45 degrees
发表于 2021-8-31 22:07:52 | 显示全部楼层 |阅读模式
How would you weld a fillet weld using 7018AC with one side vertical and one side sloped at 45 degrees ? Weave and push uphill like V-up or drag like flat ?? Thanks
Reply:Drag. The same method for welding 6G pipe uphill.
Reply:Thank you
Reply:Slight weave is OK too.
Reply:If your asking, you may not be the right guy for the job. Just saying.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by snoeproeIf your asking, you may not be the right guy for the job. Just saying.
Reply:Originally Posted by MNREAPERDon't be a dick the guy was just askingSent from my iPhone using Tapatalk
Reply:Originally Posted by CEPWOW! 75 posts, and you talk to one of the best welders on this site that way. PEOPLE!
Reply:Originally Posted by MNREAPERHe posted in the general welding questions so to receive a response like that seems ****ty to me.
Reply:BTW the OP lists himself as Retired.  So he is probably the only person for the job.  Unless someone is volunteering to go do it for free....  Sent from mobile.  Not responsible for TyposTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Maybe I am posting my questions in the wrong place. Is there a better place to post my dumb questions ?
Reply:Originally Posted by CEPIf you think that is sh!tty. You really shouldn’t hang around with welders! They will chew you up, and spit you out!
Reply:Keep asking g man, just remember here like anywhere else it takes all kinds of people to make it what it is. You probably already knew that since you made it to retirement.Mike
Reply:Originally Posted by KelvinWhere's SundownIII when you need to call in an air strike???
Reply:Originally Posted by g_manHow would you weld a fillet weld using 7018AC with one side vertical and one side sloped at 45 degrees ? Weave and push uphill like V-up or drag like flat ?? Thanks
Reply:Originally Posted by MNREAPERP.S. If in fact he's building a trailer and it kills me... then f*ck me, you were all right haha
Reply:45 degree welds can be deceivingly difficult. i had a feller straiten me up once and tell me,"its really simple kevin, as long as you dont forget which way is "up". "there is a lot of truth in that. point the rod ever so slightly "up" and just follow the joint otherwise with a slight weave or just strait across, depending on desired bead size. just remember "up". "forward" is the other half of that equation that also plays an important part. every move should be "up" and/or "forward"bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:If doing a multi-pass weld or a little wider weave you have to remember to keep the puddle horizontal while going up at the 45 otherwise your bead will sag on the down side and  have undercut on the top side. This takes some practice to remember. I wish I could show a diagram of what I mean. You want your weld to go like this --- even though the joint goes like this  /.
Reply:I think I understand-you are saying build a set of stair treads. Thanks for all the tips and don't worry I am not going to build the log trailer until next week
Reply:Seen as his previous post with photo's, he was welding on scrap and admitted he was practicing. I would "assume" he is practicing this procedure too? So read through the value added posts and skip the banter posts. Post up photo's of your practice pieces and I reasonably certain you will get the answers to your mistakes!
Reply:Originally Posted by g_manI think I understand-you are saying build a set of stair treads. Thanks for all the tips and don't worry I am not going to build the log trailer until next week
Reply:Originally Posted by g_mandon't worry I am not going to build the log trailer until next week
GMT+8, 2026-1-2 22:03 , Processed in 0.098443 second(s), 18 queries .
