Bugging out! Bug-O mig welding.
发表于 2021-8-31 22:07:50 | 显示全部楼层 |阅读模式
Here's a little project I am working on. Used a Bug-O fixture to hold the mig gun, it makes it easy to put down a bunch of weld without burning my hands. Flange is welded to 24" schedule 60 steel pipe (.97" thick). Groove weld inside, 1"fillet outside. Pulsed spray with Miller Axcess 450, .045 wire. Pipe is rolled as it's being welded. IAMAW Local 330Airco 300 AC/DC HeliwelderAirco Dip-Pak 200 with Profax spool gunPowr-Kraft AC225Everlast PowerArc 200stBuffalo Forge No.21 drill pressSpeedglas 9100xxAirco, Oxweld, Purox, Victor torchesLincoln Ranger 8
Reply:Yeah I really have no clue how to rotate these pictures, sorry for the sore necks everyone. First pic is feeder display, second is close up of finished fillet weld. This thing will be pressurized to about 1000 psi when it's done.IAMAW Local 330Airco 300 AC/DC HeliwelderAirco Dip-Pak 200 with Profax spool gunPowr-Kraft AC225Everlast PowerArc 200stBuffalo Forge No.21 drill pressSpeedglas 9100xxAirco, Oxweld, Purox, Victor torchesLincoln Ranger 8
Reply:Ohh come on, that takes the fun out of welding.Millermatic 200Miller Spectrum 2050
Reply:looks good!!-DoogieMiller 350PMiller Trailblazer 325 EFI w/ Excel PowerLincoln LN25 suitcase welderXMT 304/22a feederMiller Syncrowave 350LXMiller EconotigHobart Handler 140(2) Uni-Hydro 42-14Hypertherm 65 plasmaWEBB Gap bed lathe
Reply:Originally Posted by TypeOhh come on, that takes the fun out of welding.
Reply:Originally Posted by derekpfeifferlooks good!!
Reply:I also find no fun on depositing material at high temp for 3.5 hours while you can do something else and let the fixture get the heat, good set-up and very good results.
Reply:That's the way to do it. What kind of rpm did you use?
Reply:For rotating the pics, GIMP is free.
Reply:Originally Posted by forhireThat's the way to do it. What kind of rpm did you use?
Reply:That MIG torch sure is getting its workout! Great job. Those beads look fantastic.
Reply:Originally Posted by Mikel_24That MIG torch sure is getting its workout! Great job. Those beads look fantastic.
Reply:Originally Posted by teh603For rotating the pics, GIMP is free.
Reply:That implies the user isn't scared of using the command prompt. A lot of people are.
Reply:Nice welds, I'm gonna have to invest in some rollers, Superb beads and so hard if you tried to do it by hand
Reply:nice work. you're making it look too easy.i.u.o.e. # 15queens, ny and sunny fla
Reply:[QUOTE=Gerry1964;5591701]Nice welds, I'm gonna have to invest in some rollers, Superb beads and so hard if you tried to do it by hand[/QU Thanks! welding this without rollers would take forever and our shop wouldn't be able to compete in this industry.IAMAW Local 330Airco 300 AC/DC HeliwelderAirco Dip-Pak 200 with Profax spool gunPowr-Kraft AC225Everlast PowerArc 200stBuffalo Forge No.21 drill pressSpeedglas 9100xxAirco, Oxweld, Purox, Victor torchesLincoln Ranger 8
Reply:Originally Posted by docweldernice work. you're making it look too easy.
GMT+8, 2026-1-2 22:03 , Processed in 0.100724 second(s), 18 queries .
