Few structural HSS installed
发表于 2021-8-31 22:07:50 | 显示全部楼层 |阅读模式
A few pics of 2- 4"x4"x3/16"hss i installed with 2"x2" bracing.These are in a Ford dealership in my area.They will be used to mount the camera/laser sensors for a Hunter engineering Front alignment quick check system.They/Hunter provided the plate i welded them to my tubes after hung in ceiling.The second is installed to the right of the one in first pic Attached Images
Reply:I think it's the second system for alignment i see in welding groups, if i recall the first one was not a really good installation,  this one for sure is properly done , don't need to see the welds   Is the 4x4x3/16 was on the blue prints ? to support a laser/camera? indoors?
Reply:Cool. A new building?
Reply:Originally Posted by snowbirdI think it's the second system for alignment i see in welding groups, if i recall the first one was not a really good installation,  this one for sure is properly done , don't need to see the welds   Is the 4x4x3/16 was on the blue prints ? to support a laser/camera? indoors?
GMT+8, 2026-1-2 22:03 , Processed in 0.094616 second(s), 18 queries .
