trailer gate
发表于 2021-8-31 22:07:49 | 显示全部楼层 |阅读模式
another gate today the guy came from orlandohe was so happy with it he gave me an extra $20have three this week Attached ImagesLast edited by ed mac; 05-16-2011 at 08:36 PM.
Reply:Easy money! You do a lot of them ed. Looks good. I am going to be nosey, what are you charging to build a gate like that?You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:Nice job!!Ya gotta spend money to make money!
Reply:If I where you I would put more welds on that mess.  I do every other diamond when I do trailer ramps.  Its amazing some times how fast landscapers can rip right threw the mesh with a 1200lb z turn.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Originally Posted by Xtreme FabricationIf I where you I would put more welds on that mess.  I do every other diamond when I do trailer ramps.  Its amazing some times how fast landscapers can rip right threw the mesh with a 1200lb z turn.
Reply:Originally Posted by jreynoldsweldingEasy money! You do a lot of them ed. Looks good. I am going to be nosey, what are you charging to build a gate like that?
Reply:any lift assist on that?www.burdettenetworks.com
Reply:Ed--Raised expanded metal on ramps provides much more tractionthan flattened expanded metal.Blackbird
Reply:Originally Posted by dave powelsonEd--Raised expanded metal on ramps provides much more tractionthan flattened expanded metal.
Reply:Originally Posted by geezerI used raised expanded on mine and traction is orders better.  However, nice job and it looks like you have a good niche and word will spread quick with good work.  How did you fab the hinges?
Reply:Thanks for posting.  I seen your other post so I had an idea.  I drilled my hinge pins and installed keepers, appears you do not need them. Thats better, the pins were a pain to drill.   Maybe work will get so good you'll have to fab a jig    I certainly hope so.  Thanks againLast edited by geezer; 05-20-2011 at 07:52 AM.Reason: added contentGeezerPower Mig 255C185 TIGBlue 175 MIGRanger 8 Kohler 20HP1974 5K Lincoln/Wisconsin Powered (Cherry)Victor/Harris O/AK 487 Spool Gun
Reply:Originally Posted by ed maci do both its what the customer want. and thank youi use 3/4 sch 40 and 3/4 solid  for the hinges
Reply:Can you show a picture of what you build to lock the gate upright?  I am adding a gate to a buddy's trailer and haven't settled on that piece yet.I use 1/8" x 1.5" angle for the frame and 1/2" for the hinges.  The mesh is welded over the top of the frame rather than under it the way you did it.  Your approach is much cleaner looking.Hobart LX235Victor 250 Oxy-Acetylene Rig (welding and cutting)Bobcat 773F-350, 1999, 4x4, 16' 10K# trailerOutdoor Wood Burner - 10 cords/year
Reply:$240 ? I hope the material was supplied by the owner for that price.
Reply:This thread is from 2011. Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Originally Posted by AKweldshopThis thread is from 2011.
Reply:Funny!  When I saw the recent posts I assumed that the original was recent - didn't notice that old date. Hobart LX235Victor 250 Oxy-Acetylene Rig (welding and cutting)Bobcat 773F-350, 1999, 4x4, 16' 10K# trailerOutdoor Wood Burner - 10 cords/year
Reply:and here I thought Ed Mac was still alive. Haven't seen him post in years.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by ThorsHammerand here I thought Ed Mac was still alive. Haven't seen him post in years.
Reply:Originally Posted by gwileyCan you show a picture of what you build to lock the gate upright?  I am adding a gate to a buddy's trailer and haven't settled on that piece yet.I use 1/8" x 1.5" angle for the frame and 1/2" for the hinges.  The mesh is welded over the top of the frame rather than under it the way you did it.  Your approach is much cleaner looking.
Reply:Spring Loaded Trailer Latcheshttp://www.etrailer.com/comparison.a...16SS&pc2=SL58WHingeshttp://www.etrailer.com/Enclosed-Tra.../HP12412G.htmlLast edited by Broccoli1; 03-18-2015 at 04:39 PM.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:If you use this style latch you may want to add these bars like I did on my trailer. Because the load on the gate going down the road caused one to break and bent the other one and my gate fell on the road. Attached Imageswww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
GMT+8, 2026-1-3 01:23 , Processed in 0.099195 second(s), 18 queries .
