Weld Trailer
发表于 2021-8-31 22:07:49 | 显示全部楼层 |阅读模式
I put this together Twenty years ago, It was in serious need of a rehab.It should be good to go for a few years now. Attached ImagesI hate rude behavior in a man.......Won't tolerate it!                   Woodrow F. Call
Reply:You miss the most important thing, MAG WHEELSNice work, look like new.Jeff
Reply:Wheels are on the way.
Reply:Looks good - I even like the color Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Nice little trailer with some good storage.  Looks great after the paint job.
Reply:Good work!
Reply:Right sexy!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:although it's not painted red it looks good. where's the sound system?i.u.o.e. # 15queens, ny and sunny fla
Reply:is that a vise stand in the front corner?
Reply:Looks great! Sometimes I wish I built an open trailer but I like being able to lock everything up and fly under the radar.Trailblazer 251Dynasty 200DXSuitcase Xtreme 12vsCarolina HV-12Old Delta drill pressVictor and (old) Craftsman torchesMobile work out of a trailer... Still acquiring my fabrication arsenal.
Reply:nice looking rebuild. Like the color.
Reply:Nice.  What did you use for the paint.  I need to pick up some epoxy spray paint for a utility trailer....Lincoln Precision TIG 185.Flex-Loc 150 torch.Super-Flex hose.Lincoln MIG 180.Victor Oxy/Act torch set.DeWalt Bandsaw with SWAG stand
Reply:Vise stand on the left, chopsaw stand on the right. The paint came from Tractor su
Reply:pply. New Ford/New Holland Ford blue. Lays out really well, we'll see about the durability.
Reply:It looks even better. Well done. What method did you use to remove the rust?PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Well done. That is one sexy looking trailer since you spruced it up. Chad
Reply:Originally Posted by Chad22Well done. That is one sexy looking trailer since you spruced it up. Chad
Reply:Looks great.  I like the old black wheels.
Reply:I got a set of full moon chrome hub caps and rings that would look real sexy on that trailer! GraysOrnamentalIron.com
Reply:If registration is high, you can get SE plates from DMV in CA with no yearly charge,  they may argue it, I brought in a note from CHP saying mine qualified as long as the equipment stays in it.
GMT+8, 2026-1-2 22:03 , Processed in 0.200512 second(s), 18 queries .
