Link for cool Bandsaw modificaitons
发表于 2021-8-31 22:07:40 | 显示全部楼层 |阅读模式
Ran across this while searching for some ideas on a bandsaw table.http://www.cnccookbook.com/CCMiniBandsaw.htm
Reply:Here's the table I built for my portable bandsaw.  Made the actual table from 1/4" aluminum plate.  Made the bracket from 3/4" plywood.  The actual table is pretty rough and definitely a "prototype."  I'd like to re-build that and clean things up some...I use the HF footswitch to turn it off and on (latching footswitch).  I use a Velcro strap to keep the trigger down.KevKevin / Machine_Punk from The Aerodrome Studio - Lincoln PowerMIG 210 MP - Meco N Midget w/custom welding station - Vintage Victor 100Current Projects: The Aerodrome Studio
Reply:There is a 4x6 horizontal saw group in yahoo groups.iF you can stand that format.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Thanks for posting the link! The band saw table was nicely done!brucer-  How can I register to that yahoo group? Do you have the link?
Reply:Nice saw  setup Machine-Punk.
Reply:Originally Posted by surfsideThanks for posting the link! The band saw table was nicely done!brucer-  How can I register to that yahoo group? Do you have the link?
Reply:Originally Posted by Mick120Hey Tapweder,You posting that link gave me inspiration for modifying the one I haven't used in years.The way it's set up, is a pain to use in the vertical, as you can't stand close to the machine and, it won't go vertical when swiveled either.I don't need a horizontal as I have a bigger one and, a cold saw as well.I cleaned and dismantled it and, now intend building a new stand to use it as a permanent vertical saw.....handy for those lil chop jobs.Thanks mate......good stuff........
GMT+8, 2026-1-2 23:48 , Processed in 0.099266 second(s), 18 queries .
