Bi-metal hole saws
发表于 2021-8-31 22:07:40 | 显示全部楼层 |阅读模式
There was recently a thread about drilling in sheet or plate steel, but I don't want to hijack that thread, so starting a different one here.I need to drill a few 1 inch diameter holes in 1/8" and 3/16" steel plate.  Right now my only choices on brand and type are limited since we live in a rural area.  I was wondering what you guys have used that cut best and have durability for BI-METAL 1" hole saws.  I'll be using them on my drill press with the lowest speed and lube.  I don't have access to plasma, CNC, O/A, etc.My local brand choices are limited to:MilwaukeeBoschKleinRidgidIf I want to go with carbide hole saws and maybe include Lenox bi-metal, I have to drive 90 miles round trip (add $20 for gas).  If I gotta do that, then I'll order online.
Reply:i have Milwaukee...they work good. Just take it slow and easy as you said and lots of oil.Homedepot has them for $79 i think too.Lincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:I have used Milwaukee, Greenlee, Lennox, Starrett and Klein.  All are good AFAIAK.  I haven't used the Bosch but going by their bi-metal jig saw blades I think they would be good also.  No experience with the Ridgid but they make great pipe cutting and threading tools.I'd go with whatever you can buy cheapest, or your personal preference, they should all be fine.  Biggest factor for me is the mandrel and pilot bit assembly.  They all work but some have or don't have hex shanks on the mandrels and some have better or worse pilot bits and means of securing them.  Some will rattle themselves apart from vibration.  Again it's your preference."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:I'll second Jordan, that is the kit I have and it is pretty decent for price.American by birth Southern by the Grace of God
Reply:m-42 cobalt takes the heat of a too-fast-drillpress better than plain m-2 hss . i like morse cobalt , but  that's what i can buy locally . unless you've a macho drillpress , i wouldn't go the extra expense of carbide- most major mfgs have a premium cobalt line , but if you have the right rpm for the tool - regular bimetalshould be just fine in mild steel.anyway , whatever you choose.. hss cs= 80sfm x 4 / 1"  .  so 320 rpm for a 1" m-2 saw . cobalt cantake more heat , so 400-450 rpm for m-42  .  use lots of oil, and use a chip brush to clear the teeth often .unless you need the whole kit , a holesaw and arbor / pilot drill is inexpensive enough .Last edited by tnmgcarbide; 01-18-2013 at 11:37 PM.Miller S60 feederCobramatic push/pull feederMiller CP-252tsLincoln Tig250/Tig250Lincoln weldpak 100 -italianC-H 90A- italianHarris & Victor O\Afull manual & CNC machine shop
Reply:I understand your predicament, but I honestly think that if you're going to drill more than 5 or 6 holes in sheet, or intend to complete 1 hole in anything thicker than 1/4" (or in stainless) you're gonna want carbide. Even if it means ordering off the internet. I buy my carbide hole saws from a local industrial tool supplier "Greenshields", and they're Milwaukee brand. If there's ANY kind of industry near you regardless of how rural (you don't show your location) any kind of small manufacturer or automotive/agricultural machine shop has a supplier (like Fastenal) that probably delivers to your area, keeping your business quasi-local. I know that the carbide ones cost $40-$80 for regular sizes, but you'll burn ten bi-metals before you dull a carbide that can be resharpened. I generally keep and resharpen my carbide ones until half the teeth are completely gone, so long as the missing teeth aren't too asymmetrical.
Reply:I use annular cutters usually or the mill and a boring head but I have a set of Blu-Mol's which are just like your Milwaukee's.  They work good so long as the speed of the drill is slow and you use plenty of lubricant.  I see the Milwaukee mandrel is like the Blu-Mol.  2 extendable pins driving the hole saw.  Thats the best way actually.  You can get the hole saw off the mandrel with no hassle when you are done drilling..Most times, I'm drilling plastic or rubber and you have to use a hole saw....
Reply:I have cut 1/2 stainless plate, countless 3/4 mild steel and so forth with a plain bimetal holesaw. The key, go SLOW and use lots of coolant or lubricant. Clear chips with air from time to time and be patient.Hole saws work great, especially at the 1 inch size. I have swung a 3in into 4130 with no problems. All brands work well, but lennox seems to be my fav.SlowSyncrowave 350Coolmate 3Millermatic 251Spoolmatic 30A
Reply:Thanks guys for the input on the hole saws.REDONE, you mentioned Fastenal.  Of all places out here in the sticks, we do have a Fastenal store.  I might drop by there and see what they have.I may try out a Milwaukee bi-metal first and if that doesn't do what I need to do then I'll probably get a carbide and be done with it.  Wish the locals carried Lenox.  Their hacksaw blades are tougher than bear sh*t...use them exclusively.
Reply:Originally Posted by SidecarFlipI use annular cutters usually or the mill and a boring head but I have a set of Blu-Mol's which are just like your Milwaukee's.  They work good so long as the speed of the drill is slow and you use plenty of lubricant.  I see the Milwaukee mandrel is like the Blu-Mol.  2 extendable pins driving the hole saw.  Thats the best way actually.  You can get the hole saw off the mandrel with no hassle when you are done drilling..Most times, I'm drilling plastic or rubber and you have to use a hole saw....
Reply:Frankly, given the thickness of material you're working with, I don't think you need to over-think it very much. You're going to wear out the saw eventually. It'll last longer with higher quality, but at the end of the day, I would just buy what's convenient and then buy another one if I wore it out.
Reply:Got a Milwaukee today, will try it out first.  Probably will be a day or two before I can get back out to the shop and drill press.  Will post results.  Thanks for the help, guys.
Reply:Pin Drive saws in a hex shank mandrel are heads and sholders above the alternatives.  My favorite brand of mandrels is Starret ( the micrometer company).I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:I'm not even sure what hole saws I have. They are yellow and red ones.
Reply:Originally Posted by VPTI'm not even sure what hole saws I have. They are yellow and red ones.
Reply:Originally Posted by shortfuseCorrect answer!!!  You win!!
Reply:I'm just gonna to look for yellow and red ones...don't care who makes 'em (just joking...).  VPT, thanks for the manufacturer names.  Still haven't been out to the shop to check out the "red" Milwaukees...other stuff going on right now
Reply:UPDATE:  Finally tried out the Milwaukee bi-metal hole saw.  Worked fantastic.Needed to drill a 1" hole through an angle iron brace for holding rod and tubular stock so my drill bits would clear.  Used a 1" Milwaukee bi-metal, on 1"x1"x1/8" angle iron tacked to 1/4" thick plate.  Drill press @ 300 RPM, lubed.  Went "slow & easy"...(that's what she said).  The Milwaukee cut like a dream.  Will stick with that brand until I have a problem.  Thanks to all who offered suggestions for brands of hole saws. [IMG][/IMG]
GMT+8, 2026-1-2 23:48 , Processed in 0.093901 second(s), 18 queries .
