Precision Tig 185
发表于 2021-8-31 22:07:39 | 显示全部楼层 |阅读模式
I had a problem with my 185, when I turned it on today everything seemed to work fine, until I tried to use it.  Once i tried to strike an arc the display went out, and smoke started to come out of the machine.  I imediately turned off the machine.  I can't seem to locate the problem.  Has anyone else experienced this problem?Lincoln Precision Tig 18511108U1040812659
Reply:None have come to my shop. Get flash light and find where the smoke can from.we can make a guess what happened once we know what smoked.
Reply:I talked with Lincoln today and they have given me some input voltages to measure at the PC board. I will check it out tonite.
Reply:I have the 18 volts that is needed to operate the board, so I guess something is wrong with the board.  Has anyone ever had to have one of thes printed circuit boards repaired, if so who repaired it and how much was it?Thanks
Reply:The Lincoln service people tell me my control board is defective.  Does anyone know of somebody that repairs these boards or maybe has a used board for sale?Thanks for your help:
Reply:The board is a G-4551
Reply:Try york electronic or Gem electronic circuit board repair or industrial electronics.
Reply:paxair in st.paul minnesota repairs them. I got the same machine for sale on craiglistDaye
Reply:Innovat probably has repaired ones in stock for exchange: http://www.innovatcorp.com/Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Thanks for your help I have tried York, Gem, and Innovate with no luck.  I have sent it to Griffith Electronics and the owner Tim is checking it out.  Hopfully he can repair it.  The new ones are expensive.  If that doesn't work I'll try Praxair.Thanks again
Reply:What kind of experience have you had with your PT185?Thanks,DH
Reply:Were you able to get your circuit board repaired?  If so, who was able to do it, and how much did it cost?  I have one that also needs to be repaired.  I have a machine that welds sometimes and dosen't weld other times.  No signal to the gas solenoid, and the autobalance led won't light up.
Reply:Sorry for the delay, I haven't looked at the site for some time.  I ended up buying a new board for $900.Good luck
GMT+8, 2026-1-2 23:48 , Processed in 0.075295 second(s), 18 queries .
