lincolin to generator
发表于 2021-8-31 22:07:38 | 显示全部楼层 |阅读模式
i was wondering what kind of plug i would need to get to hook up my lincoln ac 225/125 to my duromax xp440 with an twist lock 120/240volt 30 amp?
Reply:Your genset doesn't have enough power.Unfortunately the Buzz boxes draw a lot of power because of their big transformers- even trying to weld at lower settings the Buzzboxes don't perform wellYour genset is under powered for small Mig machinesOnly 15amps @240vEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2026-1-2 23:47 , Processed in 0.113627 second(s), 18 queries .
