My Lincoln Welder with a Kokler 10 K241P engine lost its spark.I know its the coil... I work on small engines.My problem is I cant find a new coil. This coil has an extra exciter for the welder.Can anyone help with a part # or tell me where I can get this coil ?
Reply:I had one of these also on a weldanpower 150.Just order the coil assembly per the model and spec # of the engine.The black ignition coil should be removable from the armature and you can swap it to your old armature.Their are lots of aftermarket suppliers online for kohler engine parts.I personally would not try to order it from lincoln.Hope this helpsTim
Reply:Does any one have a part number ???
Reply:find the engine spec number on the label and contact a part supplier and have them look it up.with out the engine spec number it will be very hard to look up, near impossible to get the right part number. If you can't read the spec number. Get the welder code number and call Lincoln. Ask what spec number engine was used with that code number.
