thermal arc 186 ac / dc
发表于 2021-8-31 22:07:35 | 显示全部楼层 |阅读模式
Did some welds i think the machine is very smooth. Some reviews people said the there was a a slight delay on the foot pedal i didnt feel it. For the price of 2000.00 usd. I thinkg it is alot of machine for the price. So please critic on the welds and the the machine love to hear some opinions .  1 sec pre, 65 amps, 33% width, 30 amp low end, 10 pulse a sec, 4 sec. post flow Attached ImagesLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Looks only perfect to me!
Reply:ThanksLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Welds look great. Is that a gas tank?When I got my 185 back in 2008 it made my tig welding way better, and I assume the 186 has even more features.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:Looks real good!  Is this going to be a tig cooler water tank?
Reply:Tig Cooler tankLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Those 17s are no fun. Especially on AC. Why not build a AL tank? Way cheaper and it will cool the water down
Reply:Originally Posted by motolife313Those 17s are no fun. Especially on AC. Why not build a AL tank? Way cheaper and it will cool the water down
Reply:Oh cool. How do you get hooked up? Is it scrap?
Reply:Some scrap other large pieces that they'll shear cut notch and bend if i needed it to be. I fab stuff for these people They hook me up Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:DC is fine, it's when using on AC, it's there as far as a stepped/delay action. The machine has two area's where it's not as good as the previous Sanrex models. After ditching the twin switches in the ft pedal. (Problem for some units ) The stepped action/delay in response when using the machine on AC output,and the Tail-out of the arc, also when also using on AC.. The last model Sanrex was so good there, it hard to get use to the 186. Does not mean it's not a real fine welding machine, just not as nice in those areas. The arc quality is Just as good, and holds a nice point on most tungstens. I sold mine off, and found a Esab 2200i AC/DC, and it excels at the area where the Thermal does not. Of course, it's better then about everything in those two areas too..The Thermal is better with it's input power use on AC over the Esab, so it runs on a quality 6000 Genny at full 200 amps output AC. In fact the Thermal is down right impressive there..Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:So does it matter if that tanks sugars inside?
Reply:I guess it would but i ran a scope threw a bung hole  this morning and saw virtually no sugaring on the inside just on one corner.Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Oh nice. It looked like you used alot of heat looking at the bead with on the out side corner weld. What motor and pump are you gona run?
Reply:I see lot of people using carbonator vane pumps might go with that or find a centrifugal pump with a brass head and impeller .Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Heat wasnt bad 65 amps with a 30 amp low end 33 width and 10 pulse a sec. Moved along really fastLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Me and you are going down the same rhode right now. I just finished my tank too out of AL. But no motor or pump. I got a wp20 tho. What do are you going with? Htp is a good deal!
Reply:I don't weld thin stuff alot. I need to try my pulse again next time tho. Usually it always gets turned righ back off
Reply:Originally Posted by motolife313Me and you are going down the same rhode right now. I just finished my tank too out of AL. But no motor or pump. I got a wp20 tho. What do are you going with? Htp is a good deal!
Reply:Originally Posted by motolife313I don't weld thin stuff alot. I need to try my pulse again next time tho. Usually it always gets turned righ back off
Reply:Way too good!Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
GMT+8, 2026-1-2 22:15 , Processed in 0.101779 second(s), 18 queries .
