Just purchased a used Hobart 140 with an hour weld time. Never had a smaller mig before and the fan sounds quite loud. Is this normal for the small migs? I assume they are easy to replace. Also is it ok to have a grinder on the same bench as the welder...vibrations? Thanks.
Reply:My new Hobart had quite a loud fan. As do my friends' Lincoln or Miller migs. Is it making an unnatural sound or just a strong fan sound?
Reply:Just loud. I assume they are replaceable.
Reply:It will be loud,the fan runs at all times on that unit.
Reply:My little HH135 has a pretty loud fan, it's normal. Takes a good amount of air to cool things off. These machines run on the edge of hot most of the time."Any day above ground is a good day"http://www.farmersamm.com/
Reply:I was thinking of getting one of those Navy aircraft carrier flight deck helmets so I could go into the garage when my son runs the Dialarc or Syncrowave. If they didn't weigh around 400 pounds, the fan would blow them around.Welding machines are noisy for a reason. When you are running a perfect hot bead, you don't want to get distracted by the screams of passers-by who noticed that the sparks started a little fire.Last edited by Oldendum; 03-02-2015 at 04:49 PM."USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:The metal dust and wheel grit will shorten the life of the welder.The fan motor will go first,then the drive motor and wire feed parts.Vibration is the least of your worry.Circuit boards are ruined by grinder dust.In short keep grinders away from other machinery.Grinder dust gets through a lot of dust masks.
Reply:My hh140 fan is loud and runs all the time. did it from day one and I bought it new. Unless your hearing something abnormal I wouldn't worry about it.Syncrowave 210HH140Victor O/A
Reply:Originally Posted by MetalJunkieMy hh140 fan is loud and runs all the time. did it from day one and I bought it new. Unless your hearing something abnormal I wouldn't worry about it. |
