查看: 13|回复: 0
Miller Dialarc HF 300 phase 3 question
发表于 2021-8-31 22:07:31 | 显示全部楼层 |阅读模式
Can a miller Dialarc-HF 300  (blackface) be converted from 3 phase to single phase. Is there a jumper. ?www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:That machine is not three phase. It is single phase with either two or three voltage input configurations. Jumpers should be on a small red panel on one side of the machine. Jumper configuration will be listed in the basic owners manual, per what style of machine you have (i.e. 200/230, 200/230/460, 230/460/575)Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:I kind of figured. The owner does not know what he has. He said he moved shops and cannot use it now. LOL. So no matter what configuation I can still get it to work on 230 it looks like.Thanks.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Ahhh.In that case.......Uh, yeah... Yeah... It's three phase and not worth much because of that.... I've bought machinery like that dirt cheap a few times because the owner insisted it was "Three Phase". In most cases, ppl get high voltage confused with three phase power.With most AC capable TIG machines, they will almost always be single phase. Even the Syncrowave 500 is single phase. I have yet to see a Dialarc machine that wasn't 230 compatible. Should be good to go.Good luck with it.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:People think that a machine that connects to two legs of a 3-phase service is 3-phase.  Especially if it's set for higher voltage.If you only requires two hot wires, it has to be single phase."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:What about the idealarc R3R400, is that 3 phase power, can it run on a 50 amps breaker? Or 220 power? Thanks, Sam.
Reply:Lincoln site says it's 3ph and requires 75A at 230v.
Reply:You can't have AC on 3 phase with a conventional transformer. Even Lincolns AC1200 for sub-arc is single phase. Inverters can have AC on 3 phase.
Reply:One of the only AC/DC TIG machines I've ever saw was a Hobart Cyber TIG, which was solid state.Besides that, yes a machine with AC output will be 1 ph.Expert Garage Hack....https://www.facebook.com/steven.webber.948
GMT+8, 2026-1-2 23:47 , Processed in 0.097957 second(s), 18 queries .
