.062 fluxcore welding?
发表于 2021-8-31 22:07:29 | 显示全部楼层 |阅读模式
Ive welded dual shield .045 fluxcore and im good with it. However i have a weld test that is dual shield .062 fluxcore vertical postion t joint 1 fillet pass. The questions i have are is the voltage good at 25 and wirespeed at 250?Are there any certin ways to do it besides gun angle at 0° and slight side to side movement?And when they let me practice to set the machine can i run a bead vertical? Any help is greatly appreciated
Reply:25 and about 190 gun pointed upwards and slight side to side aint a bad idea. Sent from my SAMSUNG-SM-G900A using Tapatalk
Reply:I never ran .062, but I run my .045 hotter than that. If they're gonna let you practice, you should be able to do pretty much whatever you want to.
GMT+8, 2026-1-2 23:50 , Processed in 0.070473 second(s), 18 queries .
