Quick pipe fab job....
发表于 2021-8-31 22:07:22 | 显示全部楼层 |阅读模式
Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:I did a total of 8 of them.2 3/8" od, and 2 7/8" od pipe.Someone messed up when driving the poles in the ground, and these "thingy's" will move the poles over.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Originally Posted by AKweldshop
Reply:Originally Posted by Mikel_24Uh... did you actually tack welded the home-made pipe saddle to the table of your drill press? I hope it is a dedicated pipe-notching drill press!!!Great work as always and nice save!
Reply:Just a tool that needs to be used. Just like tacking stuff to the welding tableMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:This was my blue prints.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Egyptian hieroglyphs?Welding/Fab Pics: www.UtahWeld.com
Reply:some kind of concrete form?  im not quite getting the idea of what these things are??
Reply:nice quick fabrication! i liked the drill press operation! is that galvanized?
Reply:Hey guys,You'll have to wait a little for the pics.I'll show you what all these pipes do.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Attached ImagesLast edited by AKweldshop; 03-16-2015 at 07:39 PM.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Ya know your posts are always picture detailed ... great job!Located In SE OklahomaLincoln Mig 135Hobart Ironman 230 Mig5x10 CNC Table with DTHC & FTHypertherm PM65 on the tableMiller Bobcatwww.caneyagequipment.com
Reply:Attached ImagesJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Uh oh.....You weren't supposed to see that pic till the end.....Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024So.....All this work was for one reason.To move those poles that are driven in the ground, into a straight line.The clowns who put them in the ground, did not put the poles in a straight line.There is (2) 50lb bags of concrete in each hole, plus the ground is frozen rock solid.So,We just moved those pipes in a straight line. They will all be covered with gravel, so it's not a big deal on th looks.I'll try and get some better pics of the greenhouse frames, when I get a chance. ~JohnJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:nice jobHigh Octane Welding
Reply:Wow, looks like each and every pipe had to be fixed individually.....what a cluster ****.  Hey, just so it pays $.
Reply:Originally Posted by shortfuseWow, looks like each and every pipe had to be fixed individually.....what a cluster ****.  Hey, just so it pays $.
Reply:That's a lot of work. Great job. How did you get any work done taking all those pics? ;-)-JonathanFollow me on Twitter @_JonathanLewis and Instagram @superiorwelding
Reply:Originally Posted by Superior WeldingThat's a lot of work. Great job. How did you get any work done taking all those pics? ;-)-Jonathan
Reply:Vid of some welding....Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Replace the drill bit in your hole saw with an arbor like these pics and you take away the side load.  Also, I just cut crescents off the ends which works well.  It leaves a square edge on the side, but if you make a full cut, you have a tapered feather edge. Attached Images
Reply:Nice work, looks like a fun time!Personally I would put a better muffler on the welder. I couldn't take that constant noise all day long.12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:Originally Posted by VPTNice work, looks like a fun time!Personally I would put a better muffler on the welder. I couldn't take that constant noise all day long.
Reply:After looking at all the pictures of you welding my back and knees are killin' me.
Reply:Originally Posted by AKweldshopI wasn't taking many pics.   I was doing the welding, as you can see.
Reply:Originally Posted by Superior WeldingOh, you had your little brother out there taking the pics. I see now.Or was your little brother doing the welding and you were taking the pics??-Jonathan
Reply:Great set of pictures.  You had the easy part...putting up all those tubes would have driven anyone crazy!I noticed in one of the last pictures that they ran the bolt through the wood without a washer under the bolt head...wonder how long before that works loose?  But, not your problem, right?
Reply:Originally Posted by shortfuseGreat set of pictures.  You had the easy part...putting up all those tubes would have driven anyone crazy!I noticed in one of the last pictures that they ran the bolt through the wood without a washer under the bolt head...wonder how long before that works loose?  But, not your problem, right?
Reply:I'll tell you one thing john, you're industrious Sent from my dumb smartphoneTeach Ag Mech - Mike At Home:Lincoln Electric AC225Miller Challenger 172Gas AxeWork:eclectic bunch of 90's vintage blue boxes
GMT+8, 2026-1-2 22:14 , Processed in 0.072732 second(s), 18 queries .
