Picked up the steel I needed ... as well as the spindles, hubs, bearing kits, PTO shaft, wheels and tires, jack stand, hydraulic cylinder ... had to order the 1 and 3/8" PTO 6 spline as well as the pillow Block bearing ... they should be in Friday ... gotta finish a grapple unit and then Monday get a start on the Build.Located In SE OklahomaLincoln Mig 135Hobart Ironman 230 Mig5x10 CNC Table with DTHC & FTHypertherm PM65 on the tableMiller Bobcatwww.caneyagequipment.com
Reply:What kinda caddy you building?Operating Engineers Local 3Lincoln SA 200Victor TorchDewalt Grinder10 lbs SledgeWhat more do ya need!
Reply:Looks interesting, I'm with Burnt Glove though, not sure what kind of Caddy this is. Sounds like a lot of stuff going into the build pto shaft, hydraulic cylinder, grapple unit...
Reply:Based on the parts in his picture I'm thinking something along these lines except with a 3 point for a finish mower on the back.
Reply:Originally Posted by PipelinerBased on the parts in his picture I'm thinking something along these lines except with a 3 point for a finish mower on the back.
Reply:Got the grapple done ... today I'll get the balance of the parts for the caddy and get started on it.Located In SE OklahomaLincoln Mig 135Hobart Ironman 230 Mig5x10 CNC Table with DTHC & FTHypertherm PM65 on the tableMiller Bobcatwww.caneyagequipment.com
Reply:Farm country so we use "Caddy's" for the hay cutters ... AKA disc mower caddy.Located In SE OklahomaLincoln Mig 135Hobart Ironman 230 Mig5x10 CNC Table with DTHC & FTHypertherm PM65 on the tableMiller Bobcatwww.caneyagequipment.com
Reply:Originally Posted by blueriverFarm country so we use "Caddy's" for the hay cutters ... AKA disc mower caddy.
Reply:wicked
Reply:Well finally finished some walk in's ... they always good "cash" in the hand ... got a start this afternoon.Located In SE OklahomaLincoln Mig 135Hobart Ironman 230 Mig5x10 CNC Table with DTHC & FTHypertherm PM65 on the tableMiller Bobcatwww.caneyagequipment.com
Reply:Located In SE OklahomaLincoln Mig 135Hobart Ironman 230 Mig5x10 CNC Table with DTHC & FTHypertherm PM65 on the tableMiller Bobcatwww.caneyagequipment.com
Reply:Looking good!Operating Engineers Local 3Lincoln SA 200Victor TorchDewalt Grinder10 lbs SledgeWhat more do ya need!
Reply:Ya know.............................................. .....paint is highly overratedOnly problem you'll ever have with that is the hydraulic cylinder. I haven't found any good cylinders since Cross quit making them. All this imported crap now. The stinkin' seals don't hold up well at all"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Building a Caddy - one piece at a time ..."USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by Burnt GloveLooking good!
Reply:Originally Posted by farmersammYa know.............................................. .....paint is highly overratedOnly problem you'll ever have with that is the hydraulic cylinder. I haven't found any good cylinders since Cross quit making them. All this imported crap now. The stinkin' seals don't hold up well at all
Reply:Originally Posted by OldendumBuilding a Caddy - one piece at a time ...
Reply:"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Amazing!!!Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Originally Posted by AKweldshopAmazing!!! |
