Made an Annular Cutter Holder
发表于 2021-8-31 22:07:22 | 显示全部楼层 |阅读模式
Made an annular cutter holder that will be held by a 1" end mill holder for my mill. I have used 3/4" r8 collets to hold them but the stubby part of the annular cutter is really not made for a collet.Here is the first vid. There are 3 in total. Please note I am not a machinist and do not profess to be.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:You sure look like a machinist to me  I congratulate myself if I can drill a hole on center"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Looks good. I made a holder for my mill. I have a 40 taper holder and I cut the end down and added a spring in the center so I could use the center pin. 95% of the time it will remove the slug out of the center.
GMT+8, 2026-1-2 23:48 , Processed in 0.097653 second(s), 18 queries .
