Cat SR118 Skid Steer Blower,Not Very Well Designed!
发表于 2021-8-31 22:07:21 | 显示全部楼层 |阅读模式
This landed at the shop just before closing today, It's a little over a year old, 30 hours on it since the last repair. The last repair tore the fan shaft out . This will be the 3rd repair,our first on it, and hopefully for the customer the last. I don't know what they were thinking when this was designed, it's built rugged, but the fan motor is coupled with a doubled chain to the fan. As you can see it isn't anymore! The shafts out of line by almost .200 due to flexing in the tub.  We are moving the motor up top and connecting the sprockets by chain and an idler double locking the sprockets .Maybe it was  designed for only a few inches of snow,haha.  Attached Images
Reply:At a quick glance, that double-sprocket arrangement looks like a "flexible coupling" to accommodate misalignment between the two shafts.But I don't think a double-chain flexible coupling can handle 1/4" of shaft misalignment!  http://www.emersonindustrial.com/en-...couplings.aspxhttp://www.grainger.com/category/cha...ecatalog/N-clahttp://www.couplinganswers.com/2014/...ck-primer.htmlLast edited by MoonRise; 03-26-2015 at 05:40 PM.  The best laid schemes ... Gang oft agley ...
Reply:You're right ,and it didn't work either. I don't think they realized how much flex they were going to have between the  motor mount and the fan. The customers told me he looked at a new one today and they are still building them same way.
Reply:That keyway on the motor looks a little chewy also.Miller 180SDLincoln weld pak 180Hobart 250ciMill Lathe
Reply:Are there many designs like that in the east ?  Very unusual to see fan shaft and screws being parallel...While you're there, the flange bearing is also to be replaced, it has been over greased seals are popped.  Wish this thing be stored til next december.
Reply:You could do a custom coupler with a bmw guibo.  I built one to couple a skidloader engine to the hydraulic pump.  Works great. Attached ImagesMy name's not Jim....
Reply:Originally Posted by snowbirdAre there many designs like that in the east ?  Very unusual to see fan shaft and screws being parallel...While you're there, the flange bearing is also to be replaced, it has been over greased seals are popped.  Wish this thing be stored til next december.
Reply:Originally Posted by BoostinjdmYou could do a custom coupler with a bmw guibo.  I built one to couple a skidloader engine to the hydraulic pump.  Works great.
Reply:I looked at a few vids of that "cat" and really  ...not impressive, i had more confidence in the cat name before seeing that.
Reply:Yep.  It's all rubber with steel sleeves in the bolt holes.  The fabricated part is basically just two flat flanges on weld hubs.  I have drawings for the flanges somewhere.Last edited by Boostinjdm; 03-26-2015 at 10:07 PM.My name's not Jim....
Reply:Originally Posted by BrianCThe is a CAT SR118 machine, designed I'm assuming by Cat ?. The bearings were replaced when it was repaired last week by the dealer.
GMT+8, 2026-1-2 23:48 , Processed in 0.106948 second(s), 18 queries .
