Jet woodworking lathe bed support
发表于 2021-8-31 22:07:21 | 显示全部楼层 |阅读模式
My dad purchased a hollowing system for one of the small lathes and it required extending the lathe bed. We had an extension sitting in the closet but it needed support for the end. The manufacturer sells a new stand with the extension support. Why buy a new one when ours just needed some modifications so up to the shop I went for a quick little project.I used 2" x 1/8" square tube to match the existing bracing and legs. The extension base has threaded holes that run through the support leg to allow leveling. Attached ImagesTOO MANY TOOLS & NO MORE SPACE
GMT+8, 2026-1-2 22:14 , Processed in 0.097630 second(s), 18 queries .
