Hobart Super Duty F-Clamp>>> any good?
发表于 2021-8-31 22:07:20 | 显示全部楼层 |阅读模式
Does anyone have any experience with the Hobart F Clamps? (Their Super Duty clamp's in particular).
Reply:They look identical to the harbor freight ones that i have. http://www.harborfreight.com/12-inch...amp-65683.htmlAnd if they are the same you will regret them, they quickly strip out, and bind up.I recently bought the strong hand version of the F clamps, and they are leaps and bounds better than the HF brand. Got them for around 35 bucks too at my LWS.
Reply:HF clamps are great if you're working on balsa wood or cardboard.
Reply:I have a bunch of the Strong Hand Tools f-clamps.  You get what you pay for.  HF clamps are junk...the strong hand ones are amazing, but they cost quite a bit more.  The extra cost means they'll hold up to more than you can imagine.  The Hobart ones look like they fall pretty low on the spectrum (bottom being HF, top being Strong Hand)...and I wouldn't buy anywhere but on the top side with a clamp.  Especially f-clamps if you intend to use them for spreading (even if you don't intend to right now, you probably will use them for that at some point).  I'd hate to see what would happen if one of those things let go when spreading some material out.--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:Buy bessey and never regret it !MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:I'd buy Strong Hand over the Bessey clamps because of the additional utility of the Strong Hand through the accessories that can be clamped to the anvil side of the clamp.  Other than that, the Bessey and Strong Hand clamps are rated the same clamping force wise.  Bessey has options for longer clamps than Strong Hand has (Strong Hand stops at about 20" clamping capacity, while Bessey goes up to 60" in their Heavy Duty line and 36 in their Extra Heavy Duty line).  Strong Hand is made in the US, Bessey in Germany...  The Strong Hand clamps are also reversible for spreading and I don't think the Bessey's are.  Last thing is that the Bessey clamps cost quite a bit more than the Strong hand ones (jeebus they're expensive o_0).--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:Originally Posted by wintermuteI have a bunch of the Strong Hand Tools f-clamps.  You get what you pay for.  HF clamps are junk...the strong hand ones are amazing, but they cost quite a bit more.  The extra cost means they'll hold up to more than you can imagine.  The Hobart ones look like they fall pretty low on the spectrum (bottom being HF, top being Strong Hand)...and I wouldn't buy anywhere but on the top side with a clamp.  Especially f-clamps if you intend to use them for spreading (even if you don't intend to right now, you probably will use them for that at some point).  I'd hate to see what would happen if one of those things let go when spreading some material out.--Wintermute
Reply:Bessey clamps are available at Lowes which makes it nice when you need to grab an extra one.Hobart LX235Victor 250 Oxy-Acetylene Rig (welding and cutting)Bobcat 773F-350, 1999, 4x4, 16' 10K# trailerOutdoor Wood Burner - 10 cords/year
Reply:All the strong hand clamps that I've seen were made in China.Ian TannerKawasaki KX450 and many other fine tools
Reply:Mine say made in the USA on them...maybe they changed manufacturing locations at some point?  I haven't picked up any new ones in about a year and a half.--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:Originally Posted by docwelderi have a bunch of those f clamps from bessey. i hardly use them but never thought to use them for spreading. you learn something every day. thanx!
Reply:Originally Posted by gwileyBessey clamps are available at Lowes which makes it nice when you need to grab an extra one.
GMT+8, 2026-1-2 23:47 , Processed in 0.095064 second(s), 18 queries .
