Let's see your Lathe.
发表于 2021-8-31 22:07:20 | 显示全部楼层 |阅读模式
Let’s see your Lathes!!! I’m kind of on a lathe kick right now. If you feel like sharing some pics for us to see go for it!Here's the story on my Logan.A few months ago i finish up restoring my Logan lathe. I got it out of a 2nd story bowling alley. The place had an elevator luckily, but it was at the front of the building. The lathe was in the back behind the lanes and we had to go in between a lane and wall which was about 1’ wide and had 2 steps to get it up. So we had to tear it all down to get it out. It looked like at one time there was a door with an I-beam hanging out where they lifted up machines and parts in the part. It was a very old building though.  I wish they still had it. LOL But thanks to my good buddy we got it out. It was missing all the feeder gears for the lead screw but they had another motor to run the lead screw. I just haven’t put that back on yet. No need for it right now. But it runs good, smooth and straight. I’m very happy with it. It’s my 1st lathe I’ve owned. I’m no expert at turning metal but I do know my stuff. I took a few lathe and mill classes. I would love to find a nice mill next! Let me know what you guys think and if you have any tips for these lathes! Thanks I lost all the pics on my phone of us getting it out of the place and the before and during pics too Last edited by jordan_5600; 01-12-2013 at 05:15 PM.Lincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:Wow you did a nice job!
Reply:It's like buying boats... just a little bit longer... bigger.. faster.  In my garage with tooling for under 4K  Italian lathe: Graziano.    I started with the Atlas Clausing.... Thinking of selling but when I have to do something itty bitty..... Attached Images
Reply:Originally Posted by lotechmanIt's like buying boats... just a little bit longer... bigger.. faster.  In my garage with tooling for under 4K  Italian lathe: Graziano.    I started with the Atlas Clausing.... Thinking of selling but when I have to do something itty bitty.....
Reply:Do you just want the pictures or the story?The Story............... Attached ImagesMarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Originally Posted by MarkBall2Do you just want the pictures or the story?The Story...............
Reply:There are some really good deals on older larger machines since most machine shops have gone to CNC except repair shops.  This one is in prestine condition. Needed a lot of wiping down since stored 20 feet away from a flux core welder.  Thank goodness it didn't run much.    Only catch is they are discontinued line... no parts.  Someone in Europe stockpiles used parts apparently.   I am scrounging crops to build a gantry since chuck weighs over 100 pounds.  When I was at city hall getting info on garage build the guy at the counter said... "You can go bigger if you want you know... You have a large enough lot"...  That was good advice... Obviously a garage kinda guy.
Reply:Originally Posted by jordan_5600good idea with tools and things on the back there...i may have to add that....and story or just pics...what ever you guys feel like doing.
Reply:I have the early part of the story here on the WW, but that link takes you to another forum with much more info.  I've had to make a new quadrant, cut gears, rebuild the quick change gearbox several times, added some tooling & such.  I also provided a link to the story here in my sig line.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Originally Posted by MarkBall2I have the early part of the story here on the WW, but that link takes you to another forum with much more info.  I've had to make a new quadrant, cut gears, rebuild the quick change gearbox several times, added some tooling & such.  I also provided a link to the story here in my sig line.
Reply:Sears still has some parts, Clausing has some too.I need a rotary table & tail stock, then I can cut my own gears.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:The South Bend, smaller one, is in the process of having a new bench built for it. Messed up the paint last night on a pair of doors. Attached ImagesLincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:There are a couple of guys usually at Gas & Steam Engine Shows that carry all kinds of accessories for lathes and mills for the hobbiest. I had a logan once, stopped asked the guy about gears. He said what model? Opened the cabinet and he had 3 sets all stacked on a threaded rods!
Reply:Sheldon 11x56 overhead flat belt drive.  Picked it up about 3 months ago.  Great machine, love the powerfeeds (something I never had on my prior lathes).  Cuts very smooth, I added a Bison Set-tru chuck to it.  I have a couple more set-tru backing plates on the way, then a couple more chucks: Bison 5c collet chuck, Bison 4 jaw independent set-tru, and a Straight Shot Gunsmithing True Bore Alignment system (also mounts to a set-tru backing plate).  I was very lucky to find a place that could get me set-tru backing plates in the uncommon 1 3/4x8tpi spindle thread the Sheldon uses.Love this lathe, cuts smooth as butter and leaves a lovely finish.Well, here it is:--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:picked mine up for $22 at a local auction. It's a Maximat Standard.
Reply:We have three clausings in our metal shop.  Two 10 inch and one 12 inch with variable speed.  They were installed new in 1962 and have seen a lot of high school kids come through the doors.  They still work fine but are pretty loose and not real accurate anymore. Attached Images
Reply:Here's my little lathe....12" x 36"  Atlas/Craftsman.... Pic 1. Cleaned up after bringing it homePic 2. A stand I built for it...Pic 3. after a quick repaint, I would love to tear it down and redo everything but I need to use it... Attached ImagesLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Couple more...... Attached ImagesLincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Blue! Actually a nice looking color for a lathe!I took some machining classes back in the early and mid 90's. Finally got my very own atlas 10" lathe around 3-4 years ago. I tore it down right off the bat and cleaned everything up. Later I started painting parts as I rebuilt them. I couldn't get anything done without the lathe anymore. Can't wait to get a mill!Older pic of the lathe.After getting the QCGB rebuilt and bolted on.
Reply:Picked up this 14x40 Takisawa for trade. Its been retrofit with servos and ballscrews, ill be updated the control to LinuxCNC.Sent from my PC36100 using Tapatalk 2 Attached Images
Reply:Here is my humble contribution to the thread,  a Chinese 3 in 1 Mill/Drill/Lathe.....If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:He's mine.. It was a "freebie" , just had to go get it... It's a Clausing 100 series maybe a MK3a not 100%.... Hey couldn't beat the price.... I believe it was made around 1946 and is a 12 x 36..........
Reply:My 1934 Craftsman/Atlas 12x24 in it's new home.  The rest of the "lathe room" isn't done yet. Attached ImagesMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:I have 5 of them. 1941 SBL 10L, 1973 SBL 10K, 1919SBL 15" and 2 Craftsman AA109's...Bob Attached ImagesBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:South Bend 16 Inch 7 ft Bed Before:Now (restoration still in progress near complete)That is a nice SB, I really want to sell mine and buy a bigger machine,like a Heavy 10...but I don't want to be without a lathe though ...Lol...There's a guy on youtube that has done an extremely nice resto on a SB 9,and a SB heavy10...hand filed and hand polished all the controls,switch's, dials...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Here'ss my 12 X 36 lathe from Enco. It's my first lathe so I am just learning how to make chips. Attached ImagesLast edited by sanddan52; 01-14-2013 at 09:08 AM.Reason: SP
Reply:South Bend 16" x 8'
Reply:[IMG][/IMG]Mid 40s Sheldone.  Found it and a 70s Bridgeport in a garage not to far from my shop.Still have to move the compressors in the back left corner to mount them both...From the desk of Kevin CaronTrying to be the best me I can!www.kevincaron.comAHP Alpha Tig 200x MillerMatic 251Miller Syncrowave 200
Reply:my little sidney,  i should take a new picture,  ive never taken anothersince bringing it home a couple years ago.XMT 350 MPa, w/D52-DTA 185 TSWHarris of
Reply:there are a lot of nice looking lathes! I too wish i had a bigger one, but my logan was priced rightLincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:Originally Posted by jordan_5600there are a lot of nice looking lathes! I too wish i had a bigger one, but my logan was priced right
Reply:My little Craftsman 109-21270 Attached ImagesRogerOld, Tired, and GRUMPYSalesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!Dial Arc 250HFThunderbolt 225 AC/DCAssorted A/O torches
Reply:You want Lathe's huh?You got'em!First up..My baby!20"X 90" Hendy..Bullard Vertical Turrett Lathe that I am running at the same time as the Hendy..45"Swing X 42 Feet! long Gleason..Newer South Bend..Next post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Lodge and Shipley 20" "Powerturn"..14" X 60" Axleson..2 South Bends..Another South Bend with a 120" bed..That should suffice for awhile.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:And all in your shop.Sheesh, you get all the good jobs.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:damn the one wouldnt even fit in my shop. lol but you got just a few!!! thanks for sharing. Lincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:It's not my shop.I just work there....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Leblond Heavy Duty 17" that is old and tired but still get's the job done. Yes, that is an arbor press installed on the far end of the lathe.  It came with the lathe and I've never had need to move it. Small Delta wood lathe converted to metal spinning lathe. 2007 Mori-Seiki Duraturn 2550 CNC. Attached Images
Reply:Originally Posted by sanddan52Here'ss my 12 X 36 lathe from Enco. It's my first lathe so I am just learning how to make chips.
Reply:Originally Posted by Rog02My little Craftsman 109-21270
Reply:Ahhhh! Some pretty nice iron here!@lotechman, I've always thought the Grazi solution to protecting the ways as interesting if not outright genius.@Rog02, that Craftsman lathe is beautiful. It would be mid 50's at a time when Popular Mechanics was at it's peak and all things making and crafting by the talented or wishful young male homeowner was at it's absolute peak in America. Nothing was beyond reach with a little work and dedication!Totally a different mindset & world then...Matt
Reply:Originally Posted by brucervery nice setup
Reply:!949 LeBlond sliding bed gap lathe 17"/36" still a work in progress. Attached Images
Reply:20” Flather & Co lathe that was the “Cadillac” of the day back in 1917.  The company closed at the beginning of the depression. Lathe has large heavy castings and weighs 4200 lbs.  I inherited it from my father who picked it up for scrap price in 1972 for $130.  Very accurate machine that will cut just about anything. Attached Images
Reply:Originally Posted by WFM20” Flather & Co lathe that was the “Cadillac” of the day back in 1917.  The company closed at the beginning of the depression. Lathe has large heavy castings and weighs 4200 lbs.  I inherited it from my father who picked it up for scrap price in 1972 for $130.  Very accurate machine that will cut just about anything.
Reply:1924 18” Boye & Emmes that I recently sold to make room for the 20” Flather.  This was the lathe I learned on as a teenager. My father gave it to me when I bought my house in 1985. Attached Images
Reply:Here is mine, South Bend 9" Attached Images
Reply:Started out with a little Logan 12x55 1 HP lathe that had been dropped on its face and was real twisted and worn out, sold it off early last year when my tax return was about to show and bought this guy, 1956 Cincinnati Tray-Top 15x54, 5 HP.  Bought on ebay for $1350, trucked it home on a friends trailer, sold off some misc parts that I got with it, many of which didn't fit this lathe (taper attach for a Clausing, chuck mount for an old L&S, Everede boring bar holder/lantern toolpost) and made up about 3/4 of what it cost me to put a descent QCTP on it (Went with a nice used Dorian CA, maybe this tax return I'm going to trade the Dorian CA for a Dorian "Quadra" CA sized post that has attach points on all 4 corners).  Changed oil, cleaned up a lot, went thru all the oilers and lines to make sure lube got where it was supposed to, improved the factory coolant system and bought some flex tube to spray it where it needed to go.From here I'd like to get a set of metric gears and quick change plate so I can cut metric threads on it, get some smaller/nicer boring bars and make myself a backsplash guard and a holder for all my quick change tools, one day maybe a VFD. Attached Images
GMT+8, 2026-1-2 23:48 , Processed in 0.108596 second(s), 18 queries .
